Shouty Kilmer hates start-stop technology
His old Celica didn't have it! Who needs 3-10% better fuel economy?!
Then something about rod bearings and starters wearing out and endless comments of people who want to carry his baby. I never knew he was pregnant! https://www.youtube.com/watch?v=L7524u5w4ZE |
1 Attachment(s)
I would think that Shouty, as a mechanic, would see the obvious benefits of additional breakdowns and maintenance from start-stop systems.
1)Boat payments for the Mechanics weekend toys. 2)More traffic into his shop, maybe enabling him to buy more toys. 3)The additional complexity of the cars would force the inevitable switch to full electric vehicles. (This may reduce the number of hours the mechanic has to work since electric cars don't require as many repairs). |
I don't have an opinion on the technology, except that on a Prius it makes complete sense because there isn't a dedicated starter. I've always wondered how it affects engine longevity though considering static friction is much higher than dynamic friction.
Never did like shouty. I've said as much in other videos you've shown of him. Well, I like everyone, but I like his videos the least. EDIT: I decided to watch the video anyhow, and he made the same basic point I did concerning hybrids, which might explain why I don't like his videos; I just don't learn much from them, and the delivery is obnoxious at that. |
My greatest complaint about stop-start is that it doesen't activate at higher speeds.
And why should I care, since I have absolutely no idea who this person is :-)
He is a mechanic on YouTube that shouts. I would rather watch Val, who has a far superior hairline.
Even though I can understand why some people are afraid of starter failures with this device, it seems quite unavoidable nowadays. BTW those BAS-hybrid GM cars retained a dedicated starter for cold starts only, leaving the start-stop burden on the belted alternator-starter.
Even so, why should I care what he thinks? I like start/stop myself ('00 Insight, owned since '03 or thereabouts), to the point that I'm vaguely annoyed when my other vehicles don't shut off when I'm stopped. |
Cars with EOC are built for it. Mazda's is still the smoothest. Cylinder one primed to fire when the engine stops.
Mix that maybe with a small pneumatic reservoir to kick-start the engine... one that uses an accumulator to brake the engine to a stop... saves you extra wear on the starter motor. Quote:
I wish EOC was available from OEMs. Imagine an automatic-equipped car that switches off when coasting, and gently "bump starts" itself when you press on the gas pedal to overtake. :D |
Eric is good. I think I have found fault with him, but I like to point out the video where he dissected components after someone used stop leak. He showed how it made everything worse. It might work, but it seemed unlikely.
Shouty has several videos promoting stop leak. Put together they might be as long as Eric's video. "Should You Leave Your Car's Engine Idling? Myth Busted" I watched three minutes and he kept giving different scenarios. "It depends." Thanks. "Why Not to Buy an Auction Car" You cannot properly inspect it. "The Best and Worst First Cars to Buy" I quit three minutes in again. No clear conclusion. "Why It's Dumb to Buy a Smart Car" I consider "dumb" to be a weak adjective, but he lists many problems with them. He uses the same template for every video thumbnail. The same picture of him superimposed on some car. "Why Not to Buy a Car with Stop/Start Technology" I am waiting to be impressed. Has he repaired cars that broke down due to start\stop? Apparently not. "The Worst Mistakes I've Made Fixing Cars" I have tried to watch this a few times, but I know that when I have made mistakes I have tried to help others avoid doing the same things. Like watching Shouty Kilmer videos... :) "5 Things You Should Never Do in a Manual Transmission Car." I already watched "5 Things You Should Never Do In A Manual Transmission Vehicle" by Engineering Explained two years ago. It has 10M views. "How to Increase Gas Mileage in Your Car" Okay. I am done here. |
DFCO has supposedly been standard since 1996, but I cannot find a regulation for it, and when I tried to ask people who should be able to find it, I did not get anywhere.
There isn't any difference between EOC and DFCO in terms of fuel use. Both methods stop fuel from being injected into the engine. In EOC, the engine is stopped, so it's not turning anymore. In DFCO, the engine is still being turned because it's still engaged by the transmission, yet no fuel is being injected. This is why downshifting slows the car down. If it were injecting fuel then it would produce power rather than absorb it.
The advantage of EOC is that it doesn't bleed speed by turning the engine, so you can coast at a higher speed up until the point you have to slow down or stop. With DFCO, the vehicle slows down sooner because it's wasting energy turning the engine. |
I wish the start stop features were programmable.
They are to some extent ( batt voltage - engine temp) but not speed as far as i know. |
I like DFCO for hills steepr than those I can EoC down.
I prefer the longer glide distances of EOC.
In the Prius, if I recall, you can toggle "Brake" and "Drive" modes while coasting, which allows you to either EOC or Regenerative Brake down to a stop. |
https://i.imgur.com/QLKalvD.jpg |
Start-stop while moving, that sounds like DFCO or EOC and then a bump-start.
:D |
