EcoModder.com
-   General Efficiency Discussion (https://ecomodder.com/forum/general-efficiency-discussion.html)
-   -   show off your mods (https://ecomodder.com/forum/showthread.php/show-off-your-mods-21448.html)
wagonef8 04-14-2012 10:53 PM
show off your mods
Just want to see what other people are doing
http://i742.photobucket.com/albums/x...4-14173109.jpg
Took off Auxiliary lights and routed the air to radiator
http://i742.photobucket.com/albums/x...4-14195735.jpg
and my light weight battery
http://i742.photobucket.com/albums/x...07161515-1.jpg
Cd 04-14-2012 11:22 PM
That's damned clever !
Nice work.
mcrews 04-14-2012 11:40 PM
IMPUL body kit:
http://i678.photobucket.com/albums/v...G/IMG_2284.jpg
wheel skirts:
http://i678.photobucket.com/albums/v...G/IMG_2189.jpg
largest possible diameter tires:
http://i678.photobucket.com/albums/v...PG/tiregap.jpg
front belly pan
http://i678.photobucket.com/albums/v...lsplats101.jpg
rear belly pan:
http://i678.photobucket.com/albums/v...plats012-1.jpg
http://i678.photobucket.com/albums/v...lsplats122.jpg
window visors and tint:
http://i678.photobucket.com/albums/v...PG/daytime.jpg
Ecky 04-15-2012 12:24 AM
I love those skirts, I may do something like them! The clear plastic doesn't look bad at all.
mcrews 04-15-2012 01:07 AM
thanks ecky!
jtbo 04-15-2012 01:37 AM
My Kamm attempt:
http://jtbo.pp.fi/images/ZX/science/...ready_side.jpg
http://jtbo.pp.fi/images/ZX/science/..._rear_side.jpg
Also what you don't see is missing roof rails.
Also made patch to missing bit of front bumper end, then it started raining, it was +2C, not the most pleasant weather to work with car. Luckily my patch is galvanized metal, sometime I will spray it black so it is enough good looking.
Not exactly mod, but should help aero, there is also part of upper grille block visible, open hole is for IC:
http://jtbo.pp.fi/images/ZX/science/...t/zx_patch.jpg
Here is pic (again very poor pic, camera decided that it is dark even it was not) from front, my cardboard grille block does not like from water obviously. Under the car you can barely see ram air or cold air intake thing, also lower grille block. No any issues with temps with this much of blocking even going up steep hills temps stay ok.
http://jtbo.pp.fi/images/ZX/science/...lle_blocks.jpg
Still many things to do, hub caps, rear wheel well fairing and belly pan for front and rear.
wagonef8 04-15-2012 01:45 AM
Really like the rear spoiled looks like something you see on a drag car
wildfire8 04-17-2012 04:10 PM
1 Attachment(s)
How much does your battery weigh? I have a deka ETX14L. It weighs 12lbs.
Here is a link to their page.
Motorcycle Battery, ATV Battery, Snowmobile Battery, PWC Batteries - Power Sports Batteries
Download the pdf for the specs.
http://ecomodder.com/forum/attachmen...3&d=1334693063
wagonef8 04-17-2012 06:17 PM
Its 15lbs
