Showing off my new grille block
It's not the prettiest thing, but since the temperature's dropped 15F during the day today, and it's supposed to snow tonight through tuesday, I figured I'd rig up additional grille blockage.
The pieces: http://img296.imageshack.us/img296/9...4089jo1.th.jpghttp://img296.imageshack.us/images/thpix.gif Prep: http://img391.imageshack.us/img391/5...4091jx0.th.jpghttp://img391.imageshack.us/images/thpix.gif Finished: http://img253.imageshack.us/img253/5...4092rq8.th.jpghttp://img253.imageshack.us/images/thpix.gif Close-up: http://img60.imageshack.us/img60/1858/1004093fv5.th.jpghttp://img60.imageshack.us/images/thpix.gif It's straightforward enough-- Coroplast, spraypainted, and held in with zip ties. I left a gap in the center as a margin of safety, though I do have a little extra Coroplast left to fill it in if I'm feeling brave. I have yet to gauge how well it works, since the xB has temperature-idiot-lights (blue for cool, none for operating temp, and red for overheating). If the blue light goes off sooner than usual, and the red light doesn't come on, it will be judged a success. Hopefully, this will slightly help to mitigate the 3-4 mpg I'm losing due to winter gas and cold weather. |
Cool. Though isn't the top grille functional?
No, the top grille isn't functional at all. The radiator is low and wide, and only served by the two lowest grilles. The top one is actually a solid piece of plastic. I eventually want to smooth that out, because it would look good, but it's essentially pre-blocked.
Interesting. Did not know that. Cool
Looks good. You can use cardboard behind the coroplast to space it out to be flush with your bumper.
The top block isn't meant to be permanent at this point. So far, it seems to help the car warm up a little bit sooner, which is good. Long term results, of course, will be forthcoming. |
Copyright ©2000 - 2022, vBulletin Solutions Inc.
