EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Side window tufts pointing up? (https://ecomodder.com/forum/showthread.php/side-window-tufts-pointing-up-13266.html)
Gasoline Fumes 05-17-2010 10:37 AM
After tuft testing my wipers on a 1991 Civic Wagon, I thought I'd move the tufts to the side windows and compare both sides. I only have a driver's side mirror. No surprise that there's a bunch of turbulence behind the mirror, but I'm wondering what's happening here on the passenger's side.
http://img.photobucket.com/albums/09...tuftsright.jpg
Why are the front tufts pointing up? Both sides have it, but it's much clearer on the mirrorless side.
TomO 05-17-2010 11:11 AM
My VX does the same thing watching water droplets move on my mirror-less passenger side.
Looks like a very small vortex is generated by the trailing edge of the A pillar. But it look s like the flow re-attaches quickly enough.
RobertSmalls 05-17-2010 12:05 PM
My Insight does the same, with water flowing up the glass on the side where the mirror used to be.
Air is flowing up and over the car in the windshield area. As it wraps around the A-pillar, it still has momentum. I don't see vorticies.
lunarhighway 05-17-2010 12:14 PM
i have observed the same thing on my car.
i found a cfd picure that shows what goes on, because of the similar observations i think this happens on most vehicles of this layout.
http://i77.photobucket.com/albums/j5...6c4264_075.jpg
i suppose this is why the shape of the A pillar is more important than one would guess at first glance.
it seems a somewhat complex effect, and i can't really juge if it's good or bad or where the air should go ideally ( i suppose over the car). but it's interesting to note the airflow seems to originate over the side of the hood, and after it's trip over the sidewindow seems to return to the roof.
perhaps another reason why roof racks might hurt FE!
AeroModder 05-17-2010 01:20 PM
I noticed that having the driver's side front window open causes that side of my kammback to shake. That CFD model shows why. It's not allowing the air to roll onto the roof and over it.
Having the rear windows open doesn't seem to have any effect. Unfortunately, only the passenger side one works. I'll probably check the wiring on it later and make sure it's connected properly. If not, a new motor might be in order, since I removed the AC and summer is coming.
If you tuft test it again, try it with the window down a crack.
aerohead 05-17-2010 03:55 PM
low pressure
The air going around the A-pillars and over the roof is traveling much faster than the ground speed of the car.
To satisfy Daniel Bournouli's ( sp?) Theorem,the pressure must be lower there.
The tufts are attempting to 'reach' the lower pressure regime and achieve equilibrium.
This is why you don't drive with a hatchback open,as the exhaust fumes also want to migrate through the cabin when the front windows are cracked.
KamperBob 05-18-2010 06:52 AM
Originally Posted by lunarhighway (Post 174934)
I don't recall a vehicle that DIDN'T do that. Good for smokers. Good for releasing other types of cabin fumes as well. :)
Cheers
KB
NeilBlanchard 05-18-2010 08:01 AM
I will have to tuft test my zigzag tape on the 'A' pillar -- I think it helps reduce this vortex.
http://img.photobucket.com/albums/v7...d/DSC_1375.jpg
Gasoline Fumes 05-18-2010 10:30 AM
Thanks everybody! Tuft testing is fun, I might do the whole car! :D
AeroModder 05-18-2010 10:42 AM
I'm not sure if those are large enough to have any effect. Definitely tuft test it.
I found my yarn and masking tape, so I'll be doing a bit of testing myself soon.
Gasoline Fumes 05-18-2010 10:57 AM
I should get some dollar store yarn to replace my crinkly strings. :)
RobertSmalls 05-18-2010 11:26 AM
I bought some four-ply yarn, but I think it would be better to cut it to length, then tease it apart into 1-ply.
lunarhighway 05-18-2010 02:24 PM
this post got me thinking, so today i was in a parking lot and i looked at all the designs " on display" it seems that newer cars (should be the most aero one's) have a bigger radiused transition from the roof to the side, aft of the front door. combining this with the csd image, this would aid the transition of the airflow back to the roof.
another small difference that would not stand out in a profile view comparison with older boxy designs.
robertwb70 05-18-2010 04:46 PM
KB
The only car I can think of that would even have a chance of avoiding the vortex there would be the old Saab 900, they had quite a bit of curvature in the windshield, more like an airplane...for obvious reasons.
lunarhighway 05-19-2010 04:43 AM
i totally love the saab 900 (thinking about using one for a wedding car!) but ironicly it's a bit of an aero desaster...
the sadan is supposed to have a 0.34 Cd... that's ok for a car of that age, but not great, while the pretty GLI has a horrible 0.40 – 0.42... the low tail quite possibly ruines everything for this car, and a lot of these cars recieved spoilers to cure this problem. a bit like the proche 911
i totally love the styling, but most saabs before and since this model have had much better Cd's. i suppose aero wasn't much of a priority on the original 900
Tango Charlie 05-19-2010 09:35 AM
http://i337.photobucket.com/albums/n...dowairflow.jpg
On my Vibe.
