EcoModder.com
-   Instrumentation (https://ecomodder.com/forum/instrumentation.html)
-   -   SignalGuru (App + OBDII interface) (https://ecomodder.com/forum/showthread.php/signalguru-app-obdii-interface-23365.html)
cfg83 09-18-2012 08:35 PM
Hello -
Found this article :
SignalGuru app helps drivers avoid red lights
Researchers at the Massachusetts Institute of Technology have developed a system that uses dashboard-mounted smartphones to help drivers avoid red lights and reduce fuel consumption.
The app called SignalGuru predicts when a traffic signal is about to change, and the speed that should be driven when approaching an intersection in order to cruise through without stopping.
"The stop-and-go pattern that traffic signals create increases fuel consumption significantly," said Emmanouil Koukoumidis, the scientist behind the app.
http://www.youtube.com/watch?v=60nMKMvqP9Q
I say OBD II because I see this at 0:05 on the video :
http://ecomodder.com/forum/member-cf...gnalguru01.jpg
CarloSW2
Ampelmeter 01-08-2013 12:16 PM
there's a newer application indicating optimal speed. search for ampelmeter.
