Slowed down - picked up 2+ mpg!!!
I slowed from my usual 9 over the speed limit cruise to a 1 over the speed limit cruise. I didn't get a rash, so I'll keep doing it. My method was still 9 over the speed limit up to 45 mph (34 in a 25, 44 in a 35 etc). At 45, I change to 1 over, which keeps my average speed up into a more efficient range, without the larger drag from speeds over 45. This didn't work in my Mustang, but it did in the new ride...
I hypothesize that the larger engine in the Mustang was not affected by the relatively small differences in drag. At cruise rpms, the motor probably had more than enough torque to push the car, so variances between 55 and 70 had little to no effect, since long cruises never generated significant changes in FE. In a larger (wetted area) car with a smaller engine, such as the Fusion, the difference is greater. |
Compare the Cd and frontal area of the Mustang and Fusion.
:thumbup: Always room for more slowing (less tickets too)
Yeah, the gas-sucking V8 [car] is gone. The Mustang didn't have any onboard mileage devices, but I know it did very poorly at low speeds. Anything over 35 mph was a cruise in fifth gear. I think the motoring horsepower required just to turn the motor at whatever speed was in excess of the required amount to move the car. I did measure (A-B-A comparison) that the Mustang got the same mileage at 55 as it did at 70. The Fusion is an automatic, and it won't go into top gear below 45 or so, since the throttle load will keep the transmission in a lower gear, or at least out of lockup (not sure which) above 45 or so she gets very happy at low rpms. |
I keep reading people saying that as well: claims of better/same MPG with big V8's at moderate vs. higher speeds, and I'm skeptical too. Sounds like wishful thinking or maybe selective "data" by folks who like to drive fast. Maybe it's true, but I'm skeptical. (My only V8 was my first car, over half a lifetime ago!)
Just had a thought: I know a guy with a Corvette ZR1 (I think). I'm going to ask if he'd be interested in plotting a speed vs. mpg graph for it. |
