smallest mirrors
I am just wondering if any one has a reference to the smallest or most aero side mirrors. I really like having my mirrors but am looking at still getting the old girl more aero (1994 Subaru Legacy wagon)
you should modify a dental mirror to fit in a ball joint . that would be incredibly small and satisfy legalities. I would actually like at scooter mirrors if you want something usable.
move your mirrors to the inside and use the largest you can fine that works best for you, mine are 4x8 with no blind spots, just check the laws on what is ok to do.
I thought about the move to inside or even motorcycle mirrors, but im leaning more still to a car mirror. I understand it wont be as efficient as the others. But I use my mirrors a lot for driving im not sure i want to give the mirrors up, but I am still trying to gain efficiency and there has to be something much better than the stockers
factory mirrors are about 4x8......
dupree -
If I were starting from scratch I would try these : http://ecomodder.com/forum/member-cf...-would-try.jpg Quote:
deathtrain -
CarloSW2 |
I was thinking about either going full digital. small camera and twin LCD's
OR combo. small inside mirror and then nice big giant mirrors on the outside but "FLAT" and "HINGED" so above 40mph I hit a switch and the mirrors fold flat against the door window. activate a turn signal and that mirror swings open. slow below 40mph and the mirrors open. ideally. in my instance (if I ever did it) I would manually control them. best of both worlds. nice large easy to view mirrors and "zero mirrors" (except the inside mirror) at speed. but available by flipping a switch. |
Old dautsun z cars had a bullet shaped mirror housing on a rather thin pedestal. I've thought these would be good replacements.
Some of the ford probes had very aerodynamic mirrors as well, I would suggest taking a walk threw a pick and pull/ salvage yard and look for the least aerodynamically obtrusive mirror you can find.
For me the New Beetle European drivers mirror mixed with the North American passenger side mirror would provide less drag. Doing it this way you would be using the small mirror from each continents mirror set. This may be the case with other cars in Europe and North America as well. |
The problem is that ( In my case ) the mirrors need to deployed in a fraction of a second. How many times do we find ourselves surprised at an oncoming car and immediately have to look in the mirror in a split second ? |
