EcoModder.com
-   -   Smart Fortwo test drive: what do YOU want to know? (https://ecomodder.com/forum/showthread.php/smart-fortwo-test-drive-what-do-you-want-8384.html)
SVOboy 05-14-2009 03:29 PM
Have it for the day, what do you want to know about it? Picture requests? Want me to play with something particular? Post up!
cfg83 05-14-2009 03:47 PM
SVOboy -
Nag them for a manual transmission option. NAAAAAAAGGGGGG!!!!
See how much junk you can pack into it, i.e. the "grocery bag" test.
Can you easy-remove the passenger seat for more hauling volume?
CarloSW2
elhigh 05-14-2009 03:49 PM
I'd like a peek at:
-engine access for maintenance
-cargo area - I know it's small. See if you can show it with the tailgate down.
-seating area with two normal-sized humans in it: how tightly packed? Room enough to sneeze without hurting passenger?
-ask how long before they get smart about aero and add skirts/wheelcovers.
And also: envy. I'd love to give one a try, but I'm not ponying up for something that small/expensive that requires premium. Forget that.
dcb 05-14-2009 04:36 PM
what happens when you key off while moving?
SVOboy 05-14-2009 05:10 PM
What in specific about this? I'm sure I can just kick it into neutral and key off, but I won't know how it affects the transmission.
AJI 05-14-2009 06:38 PM
I've been meaning to get a drive in a ForTwo over here in the UK for a while - I really should get around to it at some point. Ideally, I'd like to try the diesel, and the petrol with the Micro (Not a)Hybrid Drive.
What I do know in answer to elhigh's question about space is that there's plenty of it. Even in the older ForTwo there was loads of space and the newer car is supposed to be even bigger inside.
dcb 05-14-2009 06:44 PM
It has a neutral? So you could EOC? If you could sort some eoc compatible feedback on it, I might suggest adding 800 pounds of "stuff" and see if it helps with the "c" :)
Oh yah, cardboard kamback too. Better get on it though, days almost over LOL
FLYBYU 05-14-2009 06:48 PM
When they first brought the Smart Fourtwo to Canada I test drove one. I'm 6ft tall and my wife is 5'6" and we both fit in no problem, it was very comfortable. We test drove the diesel version and it was pretty peppy. It had the floor shifters and paddle shifters, you could put it in manual mode and shift like by pushing either the shifter or paddles or you could leave it in auto and just drive. Manual mode was a little jerky somewhat like a regular person driving a manual. There was space for a few grocery bags behind the seat or a couple of small suitcases. The motor was easy to get too, it was under a hatch door behind the seats. There was only a can of tire sealant and a air compressor, no spare tire. They are selling ones for around the same price I paid for my Aveo, but I get a spare tire, four doors and a rear seat so the kids can ride along, and a gas engine that is easier to run in the winter time. I liked the Smart car, I just didn't see it as a primary car but rather a secondary runabout for doing errands in the city.
Electric Frenzy 05-14-2009 07:34 PM
how bad is the revised automatic transmission. I've heard it's crazy jerky in traffic. This is very high on my list of commuter cars but if it's not a smooth ride I'll take my money somewhere else.
SVOboy 05-14-2009 07:40 PM
I actually find space to be really lacking. I had to fold down the passenger seat today to bring a box to ship and the box still blocked the full rear view.
SVOboy 05-14-2009 07:41 PM
Originally Posted by cfg83 (Post 104319)
SVOboy -
CarloSW2
Even if I nag they won't do it :)
The rear bit is a good fit for about 6 single-layer bags.
Also, the front passenger seat folds flat.
SVOboy 05-14-2009 07:42 PM
Originally Posted by elhigh (Post 104320)
I'd like a peek at:
Pictures are coming for you!
I've also taken two humans out for rides in it and the fit is good. Like the CRX but with less leg room.
SVOboy 05-14-2009 07:43 PM
You could do that, indeed.
Also, I'll try to get in contact with a smart tech who can tell us what happens when you key off in neutral.
SVOboy 05-14-2009 07:44 PM
Crazy jerky is right. I feel like I'm on a tooth-chipping roller coaster sometimes while driving it :)
AJI 05-18-2009 08:53 PM
I was referring more to people space than luggage space. The boot is obviously pretty pitiful compared to virtually anything else available. I found this pic showing the boot capacity of the current fortwo cabrio model:
http://www.caradvice.com.au/wp-conte....thumbnail.jpg
Source
But it's perhaps unfair to expect the smart to hold huge loads anyway. Generally, in the environment for which they were designed (crowded European cities) you don't often need to cart huge loads about.
