Old 02-28-2009, 02:27 PM   #1 (permalink)
CLASS-8 TRUCK Streamlining / Fuel Economy ( Part-2 ) the Aero-Mods
A few general notes before we jump in,as there still appears to be some confusion over terminology.---------------------------------------------------- "Frontal Area" has nothing to do with the front of anything.Frontal area of your rig will be determined by the maximum cross-sectional area of the tractor ( if it happens to be larger than the trailer you pull,or will be determined by the maximum cross-sectional area of the trailer,should the tractor be smaller.Some journalists refer to the smaller AF of a conventional tractor compared to a COE,referring to the "nose" of the conventional.This is a complete misnomer! ---------------------------------------------------------------------------- The second point I'd like everyone to ponder when they're thinking about Class-8 aerodynamics, is that your GVW is 117,620 pounds ( 53,463 kg ).Let me repeat that.Your GVW is 117,620 LBS ( 53.463 metric tons ).How is that? When you push 95 square-feet of frontal area down the road,you displace 95 X 5,280 feet of air for every mile you travel.That's 501,600 cubic feet of air for every mile.At standard temp and atmospheric pressure,that's 501,600 X 0.075 ponds per cubic foot,or,37,620 pounds of air.18.81 tons of air for every mile.If you are running 80,000 LBS gross,and you add on the mass of air you're boxing every mile,you're actually "moving" 117,620 pounds.----------------------------------------------------------------- Okay,so let's look at some mods.Back in the early 1970s,before the first Arab oil embargo,when diesel was selling at $0.18 / gallon,the typical 18-wheeler had a Cd of around 0.85-0.88 and returned about 5.0 mpg ( maybe 4.5 mpg for anyone hauling a cattle- trailer which had Cd 1.0+ ).--------------------------------------------------------------------- From NASA/Freightliner research,it has been determined that a conventional tractor has no inherent advantage over a COE tractor.Both can be effectively streamlined.Presently,the lowest drag rig is a COE design.---------------------------------------------------------------- The careful profiling of the tractor's nose along with an integrated airdam yielded a 4.8% drag reduction.---------------------------------------------------------- The rooftop air deflector ( whether a "add-on" or integrated into a sleeper ) provided a 15.7% drag reduction.------------------------------------------------------------- Cab extenders and gap-sealers to seal tractor/trailer gap returned a 19.7% drag reduction.-------------------------------------------------------- Full-length lower side-skirts provided a 8.7% drag reduction.------------------------------------------------------------- A full-length belly pan gave a 5.9% improvement.--------------------------------------------------------- And finally,a boat tail was good for a 4.8% improvement in drag.------------------------------------------------------------------ With full aero-mods,the drag for the rig can be reduced to a level of about Cd 0.50.Without trailer mods we're pretty much stuck there.----------------------------------------------------------------- With any particular trailer "style",mpg will vary directly with trailer height.Where a 13'-6" trailer gave 5.22 mpg,a 13'-0" would give 5.32 mpg,and a 12'-6" would be 5.4 mpg.------------------------------------- Full-length lower skirts on the trailer are good for about a 19% drag reduction.------------------------------------------------------------- A full trailer belly pan will cut drag by 14.7%.---------------------------------------------------------------- A truncated boat tail of 5-degree angle and 32 inches ( 800mm ) is good for 12.6% reduced drag.------------------------------------------------------------------ The best combination created so far demonstrates a 65.5% drag reduction compared to the typical rig of the early 1970s and a mpg increase of almost 33% just from streamlining.
Old 02-28-2009, 03:00 PM   #2 (permalink)
Wow, 33% is pretty good.
Old 03-05-2009, 07:02 PM   #3 (permalink)
pretty good
If we can shave it down to Hucho's Cd 0.15 we'd be looking at a 41% mpg improvement from aero alone.Pretty radical,but so was $4.00 / gallon fuel.
Fuel Economy related papers tasdrouille General Efficiency Discussion 41 03-19-2021 06:31 PM
mileage computer for a carbureted engine diesel_john Instrumentation 221 05-01-2014 10:38 PM
CLASS-8 Truck Streamlining / Fuel Economy ( Part- 0) Brief Timeline aerohead Aerodynamics 4 03-13-2009 12:06 AM
CLASS-8 Truck Streamlining / Fuel Economy ( Part-1 ) Aero Specifics aerohead Aerodynamics 1 02-23-2009 05:16 PM
All items I scanned in the new product showcase dremd The Lounge 0 11-08-2008 04:14 PM
