Snow tires? looking for a 13" LRR option.
My old pair of 155/80 R13 Michelin snow tires are almost wore out and winter is almost here!
Michelin no longer seems to make 155/80 R13 snow tires, at least not that I can find, they do make an X-ice snow tire that is LRR but in a wider size, so is that my best option? I'm open to any brand as long as they are LRR and are studless. |
still not the right size, but the nokian hakkapeliitta R comes in 155 70 13
If you can, please post links to web sites that sell tires you mention.
nokian hakkapeliitta R 155/70 13
I just happened to be looking for these Nokian tires the other day. This is what I found.
Nokian Hakkapeliitta R 155/70R13 75R BSW free shipping - tires-easy.com > |
A 155/70R13 tire is going to be way to small for a replacement, 5.7% smaller. You would need to go with a 175/70R13 to be close. I think the Hakkkapeliitta R is probably one of the best LLR snow tires out there, but they are expensive. Nokian makes the Hakka 7 in your stock size and is still LLR, but it may no be as low.
LRR seems counter-intuitive for a snow tire. The reason you have specific "snow" tires is that they have a higher coefficient of friction in wet/snowy conditions.
I'd rather be safe in winter driving conditions than gain 3% in FE but that's just me. |
Tons of people roll around without even swithcing to snow tires. Its not unsafe, you just have to drive knowing how your car will react in a given situation (again something most people don't know).
I rolled with Hankook I pikes on the civic for a couple years. (even left them on durring the summer) They have awesome traction (FWD civic could drag it self through hood deep snow). I also got 55mpg all summer with them.
I had nokiens on the jetta, and Michelin x ices on the escort. It felt like the civic had more traction and could handle more snow even with less ground clearance. |
I've been looking at getting a CRX... apparently they had 175/70/13's stock.
These are stock for that car but will replace your 155/80's just fine. I ran both size tires on my Rabbit and didn't notice a difference in speed or mpg. Michelin*X-Ice Xi2 Tire Rack: $290 for a set after mail in rebate. ($90 per) Discount Tire: $428 for a set, reg price. ($107 per) http://www.discounttire.com/dtcs/fin...&fcb=&sw=false Uffda, new tires are 'spensive. Wish some would pop up on CL. |
I am also responsible for plowing out the long driveway at work and keeping the heat on at work and it's on a road that can take a day or more to get cleared so I often get out there with the last half mile being unplowed. The better snow tires are silica rubber, a LRR compound that has amazing grip, I have my near wore out snow tires on my car right now because my summer tires are out of balance and I haven't noticed my mileage drop. |
