So does it take almost 4000 lb of lead to= 1 gal. of gas?
I've got several automotive lead acid batteries that actually state the A/h rating on the sticker.
So I started weighing them and calculate the Wh/lb. They are all pretty close to about 18 Wh/lb. According to what I can find,energy in a gallon of gasoline is 36.6 Kw/hr. 36600(W/hr) / 18(W/hr) = 2033 lb. Let's just say 2000 pounds. But that's calculating with the 20 hour discharge A/hr rating of the battery! So unless we want to drive around at 0.5 mile/hr in super granny gear for 20 hours to justify the 20 hour discharge rating of the batteries,I think it's about half of the Amp/hour rating is what is an appropriate capacity for a one hour discharge? Is that about right? In that case can we say that it takes about 4000 pounds of lead acid batteries to eaqual the energy available in a gallon of gas? Just an interesting comparison if I did it correctly. |
I think you are forgetting the efficiency difference. Gasoline engines are maybe 30% efficient, while an electric motor should be at least double that.
Is it fair to display the inefficiency of a gas car by saying it takes about 4000lb of lead acid to equal a gallon of gas under normal driving conditions? I know that due to the efficiency of EV's it does not take that much lead to go 30 miles for example but that's kind of taking away from the EVs. This way if we tell the average joe that we carry a battery pack with the energy equivalent of 1/3 of a gallon of gas and can still go 40 miles ( I'm just making these numbers up ) maybe they get to think about it!? |
If we are talking about heat energy then yes.
But if you are talking about doing psychical work then a gallon of gas is closer to 800-1000 pounds of battery power. |
I did a generator test yesterday where 8 fluid ounces of gasoline in a gas engine was turned into an approximately constant 1.6kW of electrical power for 15 minutes out of a DC motor (and was just burned up in humungus resistors).
Well if you figure it 3dplane's way and adjust for efficiency its about 40KWH.
Pretty close to MPHomes test. So 2000 lbs would be close. I never did the math like that. Nice perspective. But hang on 3dplane, soon someone will pop in to explain to you about equivilent math and MPGe* It's sort of like Afirmative Action for EVs......... |
I've heard that 800lb of lead acid to a gallon of gas analogy but how is that fair to the EV? 18 W/hr X 800 (pounds) = 14.4 Kw/hr pack. A gallon of gas=36.6 Kw/hr so that battery pack is less than .4 gallon of gas and again that is at the 20 hour discharge rate! So accounting for Peukert by discharging it in an hour and not 20 hours makes it .2 gallon of gas equivalent? Am I doing this right? So if that EV can go 20 miles on this pack (.2 gallon equivalent) that would be a 100 mpg comparison. |
Math is not my strong side but a quick google search told me that there is 128 fl oz. in a gallon so 128/8=16 36.6/16= 2.28 Kw/hr worth of gas you turned into .4 Kw/hr (1.6 Kw for 15 min=.4 kw/hr). That would be about 18% eff? That is actually not bad for a gasser turning a DC motor. Must be a pretty decent DC motor you are using! |
If you're just comparing chemical energy, you need to also add in the weight of the oxygen from the air that's going into the chemical reaction, which IIRC is about 4:1 by weight. So if you had to carry around your own oxygen instead of getting from the air, you'd need (I think) about 35 lbs/gal.
Obviously missed expecting that when I typed post #6 |
That's if you used starter batteries for the basis of your calculation, which is not quite a valid conversion due to the fact that normally they would not take to deep cycling well. If you used a deep cycle battery with a higher amp-hour rating designed for traction applications such as the electric floor scrubber, high-lo's, electric carts/milk floats you can get closer to 72 watt/kg out of the battery rating and a lower peukert coefficient (k closer to 1.0 is better) but it still would take a lot of batteries especially if you wanted a 600km (375mi) range equivalent to say the standard 16 gallon fuel tank in a 1997 Ford Taurus for an example, if you replaced the engine with an electric machine and installed the required quantity of batteries the weight would be increased by 4559 kg, putting the overall weight at 6079.2 kg vs 1508kg for a standard Taurus
Ok golf cart deep cycle battery 220 A/hr X 6 (V) =1320W/hr
1320/67lb= 19.7 W/hr a little better than the average 18 I came up with but clearly in the same ballpark as starting batteries. And again that is at 20 hour discharge rate! And I imagine peukert bites them the same way as any lead acid but could be wrong. Imagine if battery technology could match the energy density of gasoline and we had a 36Kw/hr battery that weighed 7 lb! (or what ever a gallon of gas is) Then we could say ok I've got 10 of these in my EV that's the same as a 10 gallon gas tank in a ICE vehicle. And the EV would have a 1200 mile range! Ok I'm just dreaming. |
Then tell us exactly why you're doing the comparison against lead-acid batteries. I mean, to begin with, the stuff's about as heavy as, well, lead. If you're doing weight comparisons, it's not really a good idea to start with something that's a metaphor for heaviness, now is it? Nor is lead particularly energetic, chemically. Look at a lump of lead: what's it do? Just sits there, like thy nuncle, no? (If you remember your Tolkien.) So why not use something that's a) light, and b) energetic, like for instance lithium? |
I think the two Optima Redtop batteries that are used on Electrathon vehicles weigh about 45 pounds? And I'm fairly sure they provide ~1kWh, so at 33.4kWh / gallon, that results in about 1,500 pounds of batteries to equal 1 gallon of gasoline?
The 60 lead acid batteries used in Dave Cloud's Dolphin weigh 33 pounds each, so the total is 1,980 pounds. He has driven it ~200 miles, and those batteries are used... I think that is about 30kWh, so a little less than 1 gallon equivalent at 1 ton. The bottom line is I think your initial weight estimate is about 2X too high? Typical lithium cells would weigh less than half of that per "gallon". |
I'm doing the comparison with the metaphor for heaviness because....that's what my batteries are made out of. Lithium looks about 4-5 times better than lead but other than a few RC lipo packs,I don't have any significant amount of them. I'm not bashing lead acid nor the efficiency of ICE powertrain. I'm simply trying to come up with an answer to what is a fair/realistic way to relate to the amount of battery pack power available in an EV to certain amount of gallon used in an ICE powered car for the same distance driven under similar driving conditions,similar car etc. Let me put it this way. There is an employee at my work who comes up to me once in a while and asks me when are they coming out with the electric car? (he does that about once a month) I reply it's already out. He would then ask how far does it go? I reply 200 miles. Then he asks why only 200 and not 400 miles? This is where I wish I had a simple answer for a simple man and say: Because it would require X amount of lead acid or X amount of NiMh or Lithium to match the energy contained in the amount of gas the ICE used up to drive 400 miles! I clearly understand that due to the efficiency of the EV, to drive X miles we do not need the crazy amount of batteries that my stupid energy comparison shows but that's besides my point. Or this question. If my electric golfcart is powered by a 72 volt 100 Ah pack...( all used/murdered mismatched auto batteries 2p 6s) What size is my "gas tank"? (400+ pounds of lead) I can drive it for 10 miles before the weakest battery will go below 12 volts (and stay there with no load) while the rest of them are around 12.2V (no load) So I got a 7.2 Kw/hr pack. Can I say that I have a .2 gallon "gas tank"? (7.2/36.6=0.19) Sorry for the long babble. |
The 36.6kWh / gallon is a little higher than the numbers I have heard; which are 33.4kWh and 33.7kWh / gallon (X-Prize and EPA respectively).
Electricity doesn't weigh anything at all!
It's the container for it that's kinda heavy... I've calculated my car as roughly 130MPGe.... but my "gas tank" is about a cup! Gasoline has a CRAZY amount of energy in it. THAT'S WHY WE LOVE IT! It really is hard to get away from gasoline when it is SOOO CHEAP and SOOO POWERFUL. Great, now I am jones'n for a big gulp of gasoline. May as well get the gas bong out right now! Woot! http://300mpg.org/wp-content/uploads...4/DSC06404.jpg yeah, you're right. That's crazy. We're just shooting ourselves in the head with this stuff. http://300mpg.org/wp-content/uploads...4/DSC06406.jpg |
