Solar film - could it help power a vehicle?
I read recently about a new development in solar collectors. It was a thin film that could be put over windows to collect solar power to be turned into electricity. Apparently the electrons were located along the edges of the film.
My thought was when (or if) this technology becomes economically feasible to use, could one put it on an electric car's hood(or even on a rechargeable hybrid), trunk and roof and then help to charge the batteries with it? I don't know enough about solar power to know if a solar converter and a charger would weigh a lot. |
The issue isn't weight so much as it is the cost of the cells and their output.
Typically the cost is very high and the power output fairly low (relative to the power demands of the vehicle). People who have added panels to electric passenger cars (or hybrids) typically report that they provide a very small boost in range (let's say a couple of miles). |
To supplement the drive system they do not offer enough to warrant the expense that could be used elsewhere.
The application I have seen that is an excellent idea is their inclusion in the Aptera, which uses the solar panels only for climate control. Even when the car is parked the power from the solar panels is used to help vent excess heat from the passenger compartment. This helps reduce the power demand needed to run the air conditioning when the car becomes occupied. |
Good point, captainslug.
Well, at least one guy on here took off his alternator and replaced it with a bank of batts to avoid parasitic drag - solar film could help keep those topped up.
If I could, I'd add a couple of flexible panels to the roof of the subie and take its alternator off. Anything that might drag its miserable mileage into the thirties would be welcome. |
I thought I had read somewhere about photovoltaic paint... that someone was experimenting with it, trying to turn the paintjob on their car into a giant solar cell... I'm not sure how this would work, but it might be something worth looking into...
If nothing else, you could have the most expensive paint job on the block... :thumbup: |
Yes it exists but is not yet marketable, the goal was an inefficient solar material that cost the same as paint making it stupid not to impliment, now to see if I can find the linky.
The electric to drive a car is very cheap but the lead acid batteries sulphating while you sit at work are very expensive. One set of lead acid traction batteries would easily pay for several relatively small solar float charging systems. The main advantage of a small solar panel is to pulse desulphate and float the batteries while you sit keeping your most expensive investment from wearing out as quickly. This is assuming you sit at work during the day like I do. If your out at night no dice. |
If you're out at night, the car is still sitting outside in the driveway during the day, in most cases... wouldn't it have the same effect? Just a thought...
:thumbup: good argument pro-cell though. I'd love to see that link, so I know I'm not remembering things that aren't really there. PS did you really mean "inefficient" up there? I would wonder why they would want to make something "inefficient" is why I ask. |
Inefficient=dirt cheap
I'm still working on my wife w/ the "I can't" phrases... I hate it when she says it, and she usually says it right before finding out that "it" was one of the easiest things she's ever done. |
Yes I did mean inefficient, the goal was to make it as cheap as regular paint, efficiency was a distant 2nd so there would be absolutely no reason not to impliment because the price would be the same as regular paint. |
I was thinking about this the other day, in relation to keeping your car charged and warm, as the batteries are under more strain in cold weather and mirrors with trackers are cheap and mounting PV on something like a flat roof is not a good use as they don't get full sun and in the winter it's even less so, but if you reflected the light to the PV and used that waste heat that is created to keep the engine of the car warm on a gas car, or the cabin of the car on an EV then it turns in to a win win with solar charging and solar heating of your vehicle, in the summer the light is more intense so that extra power could be used to run a fan to cool the car.
You mean by placing the PV inside the car (EV example) and allowing the mirrors to track the sun so there is always a direct light source on the PV, and the heat from the light going through the window heating the inside of the car?
Could you sketch an example layout? |
IF so, could those PV's be stacked so that the light passing through the first has to pass into the second one, scavenging more of the light's energy? Obviously, the first one would be inefficient as compared to normal PV's, since it wouldn't be able to capture as much light energy being opaque, but the second layer could be a standard efficiency, which reflects light... Using a one-way mirror effect, with the impermeable side facing the non-opaque PV cell, would that not allow for concentration of heat, that could then be vented/directed to any where you could put ducting? What I'm thinking is kinda like this: -----------------------------------------| ~~~~~~~~~~~~~~~~~~~~~~~~~~| ~~~~~~~~~~~~~~~~~~~~~~~~~~| ================================| Legend: ----- - opaque-one way mirror PV ~~~~ - airspace ===== - Non-opaque PV | - wall/cap See what I'm saying? As the light passes through the upper layer of opaque photovoltaic cell membrane, it produces SOME electricity, maybe enough just enough to power vent fans. It then reflects off the second PV, back to the first one, which has a "light comes in but don't go out" mirror effect (like the interrogation rooms at the cop shop), which would reflect the light energy back to the primary (non-opaque) PV. The result of having the clear-ish membrane is, of course, a greenhouse effect, which would cause heat buildup, which could then be vented (after passing a wind-vane type setup, for reclamation of energy) into whatever area you could duct heat to. Now, if it isn't obvious by now, I know almost nothing about PV cells. I just like to think that I can ask the right question to get someone who does know to think in a different way... So if this sparks your million dollar idea, just give me credit somewhere, and we're cool. :P |
When you think PV think a little over 3 watts per square foot. 1 KW =1.15 HP(ish).
Using the PV to add to your distance on EV is not worth it until Solar cells go from their current 19-20% efficiency to something like 50-60%. I'm pro-PV though. If you are an 8-5er then your car can sit at work all day and charge. So. . .Let's assume your work is 30 miles. at 30 miles the Aptera would be right at the point it has to kick on its ICE to recharge batts. But. . .you had your car sitting outside all day and it was sunny half the time so. . .(My car can fit roughly 5 BP375's (12 square feet 3x4)) so thats 5*75 watts*4.5(the BP 375 produces 75 KW an hour of sunlight five of them and 4 and a half hours)= 1.687 KW. . or 2HP/hour. basically enough to keep your EV only mode on until you get home without the ICE kicking in. Also. . .If you don't go to work it can charge for free at home. . .Not that its terribly expensive but its 10cents per KWH that you don't have to pay. . . I would leave it unplugged during the day to afford the most juice from the panels and then plug it up at night(assuming you aren't going anywhere for a couple of hours. As previous replies state it would also boost you a few miles while you drive(assuming you go 30 you might get 33) |
Sorry. PV works. . .because the photons that make up light "happen" to strike the electrons in the waifer as they pass through. The semi-conductor has an electron sharing quality that allows them to be popped out of orbit easily enough that a passing photon that happens to occupy the same space at the same time can bounce them out of orbit. The photon then passes the rest of teh way through the first membrane and strike the second and is absorbed as heat, or in the case it did not strike an electron in layer 1 it may still have enough energy to pop an electron loose in layer 2. PV is difficult because you are relying on the probability that a photon will strike an electron. Of course we can improve our odds(originally PV produced far less like only 1% of the time did a photon bounce an electron out of orbit opposed to the 20% we see now) by using things that are better semi-conductors and allow for a more. . .evenly(?) distributed electron field to improve our chances of a collision. Thats what the big race in PV is. Find a semi-conductor compound that distributes electrons in a fashion that they are out there and get a "hit" 50% of the time. . .or actually just 25% of the time per layer for a total of 50%. . .different materials for different wavelengths of light otherwise it just sails right past.(Blue and Green are the most common forms of light in our solar system thats why they are blue and green(also why plants are green)). |
I'm curious-I know that the PV 'trickle charge' is pretty useful in extending battery life for Lead Acid, but does it help any for NiCad, NiMH or the Lithium families? Or do you just get the extra mile or so of performance?
Thats' a good question, I never really thought to ask... I second it.
I like this idea. This way not only would the window tinting keep the car cooler by limiting the sunlight getting in, but it'd use some of that sunlight to power vent fans and further cool (or heat, I suppose) the car. Nice!
I'm going to gamble no it does not extend the "new" batteries. The cells run on the idea of allowing two compounds to react in the presence of oxygen. The trick is there must be a barrier that allows oxygen in and not water. The barrier can be alot of things depending on the price of the battery. For the life of me I cannot remember what the two most common compounds are(one is cheap and the other is rather expensive).
Anyway those batteries run out when that membrane goes bad. When that happens the cell doesn't limit flow correctly and you end up getting compounds different than what the designers intended and you can't make the battery run in reverse. So slowly over time you get a new compound that does not revert back to say Nickel and Cadmium, and eventually most of your materials have become this useless compound. A solar film for windows would be nice, except half of them would be either facing away or at a very bad angle. although it would decrease ambient temperature in the cab during the summer, I'm for it. . .when PV comes down in price ^_^ |
I like the PV window tint... but too many states wouldn't like it. It would be another overseas technology.
PA gets pissed at people that have those one-way murals in the back windows of their trucks... they're not illegal, but cops still complain to drivers about them. I can imagine what it would be like to have semi-reflective or even charcoal colored PV in all your windows. |
