Old 04-15-2009, 01:39 AM   #1 (permalink)
In hypermiler central
[SOLD] Highway Warrior - '00 Mazda Protege LX 1.6L Manual
90 day: 35.93 mpg (US)
Basic Miata - '06 Mazda Miata Touring
90 day: 30.93 mpg (US)
Send a message via AIM to 1337
Does anyone know the ratios for Metro/Swift automatic transmissions?
I keep seeing talk about the manual transmission ratios in manual Swifts and Metros (3cyl and 4cyl) from various years. However, I'm having trouble finding a list of automatic transmission gear and final drive ratios.
I'm just trying to get an idea of how fast an automatic Metro engine would turn on the highway.
2006 Miata Touring 5MT
2006 VW Jetta TDI 6AT (Sold to buy Miata)
2000 Mazda Protege 1.6L 5MT
2002 Mercedes C230 Coupe 5AT (Water damage, totaled)
DeepScale
Old 04-15-2009, 01:44 AM   #2 (permalink)
Oh, I found some information, but I still don't know the final drive ratios. I also don't have any info on any automatic Metros other than a '97 I4.
From GM website: 1997 Geo Metro
For 1997:
TRANSMISSIONS
5-speed manual 5-speed manual 3-speed
w/ overdrive w/overdrive automatic
(1.0L L4 engine) (1.3L L4 engine) (1.3L L4 engine)
Gear Ratios 1st 3.42 3.58 2.81
2nd 1.89 1.89 1.55
3rd 1.28 1.28 1.00
4th 0.91 0.91 ----
5th 0.76 0.76 ----
Reverse 3.27 3.27 2.30
DeepScale
Old 04-15-2009, 07:55 PM   #3 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
Metro Transmission and Speedometer Gear Ratio Information–MetroXFi.com
* 3.52:1 1.3L SOHC Swift up to mid year ‘95
* 3.79:1 98-01 4 cylinder Metro
* 3.85:1 XFi Metro
* 3.95:1 mid year ‘95 up 1.3L SOHC Swift
* 4.10:1 Swift GT, GTi, 95 and earlier Metro
* 4.39:1 Metro Convertible, 96+ Metro
GeoMetroforum.com - got mpg?
Old 04-15-2009, 08:32 PM   #4 (permalink)
So, final drive ratios are the same for a given year/model, regardless of whether it has a manual or automatic trans?
DeepScale
Old 04-15-2009, 09:33 PM   #5 (permalink)
nut
Coyote X's Avatar
Metro XFi - '93 Geo Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 Suzuki DR650SE
90 day: 55.26 mpg (US)
Send a message via MSN to Coyote X
yep the final drive ratio is the same. The auto just makes the motor scream at higher speeds with the 1:1 3rd gear. It doesn't seem to hurt them as far as life of the rings/bearings it just makes the mileage suck over 55mph
Old 04-15-2009, 09:37 PM   #6 (permalink)
Oh, ok, thanks for the help!
Someday, if I ever get the time, I'd like to buy a 3 cyl Metro and install a 4 cylinder transmission.
I'll practically be able to cross America on gas fumes...
DeepScale
Old 04-15-2009, 09:40 PM   #7 (permalink)
Actually, to be 100% ideal, I'd want a 3cyl engine, a 4cyl transmission with a first gear from a 3cyl transmission. That way, I could have low revs on the highway, but I wouldn't burn up the clutch by slipping it a lot when starting from a stop.
DeepScale
Old 04-16-2009, 12:20 PM   #8 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
Be sure to get the 8-valve's tranny, not the 16's. When Suzuki built 'em that way, they also had a milder cam for low-end efficiency, etc - the XFI setup. You can push it even farther with big, LRR tires and improved aero.
Old 04-16-2009, 09:43 PM   #9 (permalink)
Hi-Tech Redneck
If you drop in an economy grind 3Tech cam and a 10 degree advanced timing gear, you can let up on the clutch without touching the gas and the car won't stall
Here you go............
3Tech Performance
Why I'm Choosing a Civic Over a Metro Wayneburg General Efficiency Discussion 43 03-02-2011 05:11 PM
Locking an automatic in a single gear? bennelson EcoModding Central 11 11-14-2008 01:03 PM
Hypermiling w/ an automatic tran? walkerjody Hypermiling / EcoDriver's Ed 11 10-03-2008 05:14 PM
Metro automatic trans mod. engineer93065 EcoModding Central 15 07-02-2008 01:01 AM
News: VW has sold a million DSG transmissions MetroMPG General Efficiency Discussion 5 02-06-2008 11:10 AM
