Originally Posted by serialk11r
Note that 1% of the earth's surface is a metric s***load.
But yea the white painted surface is actually cooler than the air around it is correct (weather dependent though, doesn't work if the sky isn't clear). The high emissivity is one reason why white is cooler than even a very reflective silver. The silver just reflects most of the heat, while the white actively radiates if its temperature is higher than the surroundings.
it is.
A start would be under or around DOUBLE SIDED, Bifacial Solar Panels as I NB the the frequencies reflected by this paint is very good for solar panels.
Also; the paint is turning std heat into the correct frequencies of light, so one should do better than the numbers n the video below.
Also very interesting is vertical Bifacial Solar Panels (with reflectors) because:
They dont get snow and sh!t on them.
Can be used as fencing.
Can easily have crops grown between. (but that puts paid to the reflective thing)
Cuts 'Clipping' At mid day, while giving you more power in the mornings And evenings when you want/need it.
Run cooler = more efficient.
https://www.youtube.com/@ProjectsWit...query=verticAl
(Dave is worth watching because he's an engineer that collects the data = does the science correctly).
While Barium Sulfate is 98% reflective IIRC, plain old (crushed) limestone, at 95%, is a hell of a lot cheaper as a ground cover. (or Whitewash for walls and roofs)
I wonder how much better cheap Whitewash, with a touch of Barium Sulfate in it would be..?
Some interesting info, but no mixtures. Not much difference, except for price!
Subambient passive radiative cooling effects of barium sulfate and calcium carbonate paints under Malaysia's tropical climateThe BaSO4 cooling paint was able to achieve subambient temperature reductions of up to −6.1 °C and a mean net cooling power of 71.0 W m−2 while the CaCO3 cooling paint achieved a maximum subambient temperature reduction of −6.0 °C and a mean net cooling power of 69.9 W m−2.
