EcoModder.com
-   For Sale (https://ecomodder.com/forum/sale.html)
-   -   SOLD: 2004 Civic hybrid MT, $500 (https://ecomodder.com/forum/showthread.php/sold-2004-civic-hybrid-mt-500-a-36735.html)
samwichse 08-20-2018 06:55 PM
EDIT: Car is SOLD.
I've got a gray Civic hybrid with a manual transmission for sale.
Here's what's right with it:
-The interior is in pretty good shape
-The engine runs well and pulls smoothly
-IMAC&C and OBDIIC&C included with the car
-Transmission shifts nicely and no grumbling
-No shimmies/shakes at speed
-Grid charger harness installed with Peter Perkins fan speed control board
Here's what's wrong with it:
-Failing IMA battery. ~5 year old Bumblebee unit doesn't gain much after a grid charge. Consecutive charges/drive cycles will probably get you through emissions inspection if you use IMAC&C to zero out charge/discharge
-Burns some oil (1qt every other fill up?). It's a Honda L13...
-Body looked pretty good until my neighbor backed squarely into the driver's side door. Still opens and closes fine, looks...
-Rust bubbles above both rear wheel wells
-Wheels have curb rash from PO.
~150k miles
Driving it as is, it's a manual transmission Civic with a smaller than the smallest engine civics came with in the US. It will lean burn (OBDIIC&C has a nice green LED to indicate). It has the equivalent of an alternator delete at idle. Over 1500 RPMS and the IMA system will charge the 12v even with a dead HV battery.
Still an excellent eco-car with a body you wouldn't feel too bad about aeromodding. Or put a new HV battery in it and it will get 50 mpg pretty easily (doesn't matter so much on the highway). Transmission has a nice tall final drive that can swap with several other Hondas, apparently.
Sam
EDIT: photo album here with more pictures:
https://photos.app.goo.gl/PkaSkVN8JLym88pH9
https://lh3.googleusercontent.com/L6...=w1131-h849-no
https://lh3.googleusercontent.com/_R...A=w636-h848-no
jcp123 08-20-2018 08:26 PM
Man, where was this last year when I wanted a beater car? I could have justified this buy...
samwichse 08-22-2018 12:04 PM
Updated with a couple pictures and a gallery link.
442hybrid 08-22-2018 09:47 PM
Never knew you had a civic hybrid,,we have 340'ooo miles on our o3 civic hybrid, son loves it,,good luck with sale,,
samwichse 08-25-2018 12:21 PM
I drove it to last year's fall maintenance day at Lincoln Tech :)
Copyright ©2000 - 2019, vBulletin Solutions Inc.
