Someone asks: Metro/Swift taller transmission swap... is there a 3.28 final drive?
Someone e-mailed me this question:
I wonder if you're seeing figures for the new Swift that's available in Europe, and which is a completely different car than the Metro/clones we had here until 2000(ish). As for getting the 3.28 result comparing input to output revolutions, I'd want to double-check that to be sure. |
Fourth gear on these is an overdrive. 3.524 x 0.914 = 3.22. Pretty close to 3.28. :)
Counting the ring/crown gear teeth is more accurate. Just pull off the triangular plate and start counting. 3.52 has 74 teeth. 1989-1994 US Swift/Metro 5-speed: 1st = 3.416 (3.583 1998+ 1298cc) 2nd = 1.894 3rd = 1.280 (1.375 non-US GTi) 4th = 0.914 (1.030 non-US GTi) 5th = 0.757 (0.870 non-US GTi) Reverse = 3.273 |
