Sooner or later
Every new car goes to a salvage acution.
https://www.iaai.com/Vehicles/Vehicl...&RowNumber=285 regards Mech |
Man, wish I could pick one up at that price!
First look: 2012... current bid, $1,600! Whoa!
Second look: Flood. Oh. - Wonder how much of the hardware is salvageable... the motor should be water-sealed, right? |
It's a crap shoot. Spend 5k + fix it or use it for parts. You can build 4 with it. Front end, each side, rear end. You still have the whole powertrain and interior left over and 4 repaired cars, but it takes time and a good deal of money tied up for a while. I have also fixed water damaged cars, and most of the parts you need are the ones the salvage yards never sell.
Only thing my Fiesta has needed in 11k miles is to have the accent light switch plugged in, was not done at the factory, they (body shop) never touched the dash or console. An oil change at 5k and 12.5k, next one at 20k. The estimate on that Prius seems low at less than 6k. Would have liked to look it over when it was still showing the water level and type (salt or fresh, makes a big difference). Fixed an 82 300 SD Benz once that rolled into the Atlantic Ocean off the owners boat ramp. $8500 30 years ago. regards Mech |
NSTAAFL
No such thing as a free lunch! |
Quick, someone swap in a 3 cyl diesel and build a fiberglass boat tail.
We checked the tranny and diff, no salt water contamination. Never replaced a single part on the truck and later sold it for close to $30k. Knowledge is a powerful tool, expecially when combined with a dogged determination to succeed. I can fix just about anything, which means the question is how much does it cost and how long will it take. In the case of this Prius C I have plenty of time, suffecient capital, and the facility. All are paid in full and the capital is not doing well in other investments. I don't even have to fix the car, just part it out and sell the parts and easily double (or triple) my money, but it would take 5 years. I also have a friend who is the service manager at the local Toyota dealership who would give me technical help fairly inexpensively. regards Mech |
It wouldn't surprize me if some of the owners "accidentally" let their cars get flooded. You know, it's old and needs a lot of work so leave the sucker where the water will get to it and get paid on a comprehensive claim.
I'll bid on it tomorrow, but my buddy (who owns the body shop that will buy it) doesn't think it will go that cheap. Stopped by the Toyota dealer today and the most likely damage is to the air bag modules and wiring harness as well as the pretensioners for the front seat belts. If I get it then I will tear it down to see exactly where the water level was and whether it was fresh or salt water. Can't do any thorough inspection prior to the sale date, but as I posted earlier it would be worth my bid amount even if I had to part it out. Regards Mech |
good luck....start a thread if you get it!!
Will do that mcrews, I will need some advice on maintaining the hybrid battery if it takes a long time to get the car fixed. It was built 4-12 and has just over 6k miles, so it has probably been off the road for 5 or 6 months.
I'm not going to go very high one the price, when I first posted about it it was at $1100, now it is just under $3k. I will know in the morning before lunch. regards Mech |
I wouldn't be afraid to get a flooded car if I could get it considerably cheap. But the entire vehicle needs to get dismantled, washed, the electronics to be cleaned with isopropyl alcohol and then get all reassembled.
It's a 2012... so there should be no corrosion from a single dip in water.
Parting it out would cover the purchase cost easily if it goes for under $3k. Then you use the light, aerodynamic shell and shove a nice new motor into it. |
The old man (72) who owns the body shop called me and told me the plugs had been pulled from the engine, so it had injested water, with potential bent connecting rods and other damage. I was going to bid $5500 but with that knowledge I dropped the bid to $4500.
It went for $6600 without the additional $3-400 in fees. Maybe next time but I don't need it that bad. Already have 7 vehicles total and I need to sell 3 of the bikes this spring. regards Mech |
