Sparkplugs
2013 Toyota Corolla , has 63117 miles on it. It's been getting crappy mpg lately.
Started to get a misfire randomly code p0300. Changed plugs and coils. Ceramic is burnt. Trying to attach picture for you guys to see. Electrodes are gray. |
Found this on line.
What Causes a P0300 Code? Low Fuel Pressure Vacuum Leak EGR system malfunction Internal Engine Problems (such as low compression) Less Common Causes Faulty Coil Faulty Spark Plugs and/or Wires Camshaft or Crankshaft sensors Ignition module Computer |
