EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Speculating about a Bajoosed 5-speed Insight (https://ecomodder.com/forum/showthread.php/speculating-about-bajoosed-5-speed-insight-8088.html)
Chuck. 04-25-2009 12:42 AM
I'll describe my 2000 Honda Insight 5-speed and my results, then hopefully someone can project what it might do with aeromods similar to basjoos put on his Civic.
Since the Insight is .25 like the 2010 Prius, it's Cd is exactly halfway between basjoos before and after Civic Cd. In other words, the aeromods likely would yield about half the results of the 92 Civic.
The results are about the same as stock except my use of the FAS switch on the MIMA installation and occasional the hot air intake.
The 5-speed Insight at 70F+ on a level highway with no load or A/C will lean burn up to about 65mph.
Cruising at 45 on a highway, the results from cold to hot weather is 75-115mpg - 85-95 being more a more typical range.
MPG at various speeds:
  • 110mpg @ 40
  • 100mpg @ 50
  • 80mpg @ 60
  • 60-65mpg @65
  • 50mpg @ 70
  • 35-40mpg @ 85+
Since there is a speed limiter, it maxes out at 113mph (I did it twice over five years ago :o )
Chuck. 04-25-2009 01:17 AM
The critical information is the % increase the Civic got after aeromodding.
A similarly modded Insight probably would get half of that % increase.
Chuck. 04-25-2009 02:13 AM
  • 110mpg @ 40
  • 100mpg @ 50
  • 80mpg @ 60
  • 60-65mpg @65
  • 50mpg @ 70
  • 35-40mpg @ 85+
Guesstimating the AeroCivic improved 20%, I'll say a 5-speed Insight would improve 10%...
Cruising at 45 on a highway, the results from cold to hot weather is 90-138mpg - 102-114 being more a more typical range.
  • 132mpg @ 40
  • 120mpg @ 50
  • 96mpg @ 60
  • 72-78mpg @65
  • 60mpg @ 70
  • 42-48mpg @ 85+
Daox 04-25-2009 09:02 AM
I could be remembering wrong, but I recall the boat tail increasing basjoos' mileage by 17%. I think it would be great to see what a little aero tweaking could do for an Insight! We know that .25 is good, but can definitely be improved upon.
Funny, Darin and I were just talking about what we would mod if we had an Insight since so much is done to it already. We still came up with a fair size list... and I see he started a thread for it even. :)
SVOboy 04-25-2009 12:53 PM
Are you monitoring the AFR of the lean burn? You might get a larger improvement because of a more dramatically lean AFR as well.
KJSatz 04-25-2009 01:12 PM
I would love to see an insight with a boat tail....
Chuck. 04-25-2009 01:29 PM
:o What is AFR?
aerohead 04-25-2009 02:31 PM
speculating
A 10% drag reduction will give you a 5% mpg improvement at a constant 55-mph,and 6% mpg improvement at 70-mph.You can play around with different scenarios and noodle the differences.
Chuck. 04-25-2009 02:36 PM
Then I need to half my projections to get close to reality.
I live maybe 15 miles from you in Lewisville, BTW
MetroMPG 04-25-2009 02:36 PM
Phil, do you know if that formula also holds for lean burn conditions, or just stoichiometric?
You can also plug the numbers into the aero/rolling calculator:
Aerodynamic & rolling resistance, power & MPG calculator - EcoModder.com
But again, I'm not sure what the implications are for lean burn engines.
aerohead 04-27-2009 06:59 PM
basjoosed
If you drop the Cd0.25 to 0.17,at 55mph,your mpg will go up 16%.
basjoos 04-27-2009 10:16 PM
A quick way to estimate your car's mpg aeromodding potential is to go out with a friend and close draft their car at various speeds while noting your mileage, as this will be the mileage that your car's engine-transmission-tire combo will be getting when you reduce the aero load on your car. Then you can decide whether the mileage improvement you can potentially get is worth the effort of doing the aeromods.
rkcarguy 04-28-2009 12:34 PM
I think the insight has better potential in that it is more CRX like in shape and not as tall as the civic hatchback. Basjoos is also running the DX engine and there is more to be gained if you explore using a VX or HX lean burn engine.
Chuck. 04-28-2009 12:40 PM
The Insight is next of kin to the CRX HF but notice the Insight tapers at the end for better aerodynamics
http://www.cleanmpg.com/photos/data/...ht_and_crx.jpg
My current car on the left - a near identical car to the 88 CRX HF I had for 250,000 miles.
rkcarguy 04-28-2009 12:42 PM
99 CRX ? I'd like to have one that new:)
