EcoModder.com
-   Instrumentation (https://ecomodder.com/forum/instrumentation.html)
-   -   Speedo reprograming (https://ecomodder.com/forum/showthread.php/speedo-reprograming-14603.html)
KCF3712 09-19-2010 09:21 PM
Speedo reprograming
Does anyone know if you can reprogram the computer / speedometer to compensate for a tire size change?
Thanks in advance
KCF3712
Weather Spotter 09-19-2010 09:44 PM
This might sound simple, look in the manual. If it is not there, try your favorite search engine.
I have heard of it being done, not sure you can do it.
Now if you had a ScanGauge, there is a setting for that.
gone-ot 09-19-2010 09:46 PM
...for GM products, there's an after-market "box" that can be connected in-line with the wheel Speed Sensor that allows you to 're-calibrate' the number of pulses per mile being sent to the ECU.
...unfortunately, I don't know of anything similar for a Kia.
