Speedometer Stop Working While Driving
Just moments ago, I was approaching the off ramp from the expressway, when I'd noticed that the needles on my speedometer & tachometer started to fluctuate on my 94 Civic Vx. Shortly afterwards, they stopped working all together, along with the trip odometer and mileage counter.
Additionally, what I'd also noticed was that there wasn't any power to my radio; but where it really got interesting was when I'd gotten the car home. Just when I had shut off the ignition and attempted to restart the engine, the car behaved as though it had a dead battery. In retrospect, I was at the drive-in tonight watching a double feature with the radio on (i.e. yes we do have one in my parts). I'm wondering if I just have drained battery....any additional thoughts on the matter, in terms of what I should try? |
Start with easy stuff first, clean all battery connections and engine grounds. Test the battery voltage and recharge if needed. Before recharging check battery fill level if you can.
Alternator should charge the battery. If not, follow what nemo said.
Otherwise, next time it does it, push in on and wiggle the key. The electrical connectors in these wear out. |
I am going to try these suggestions. Question is, "Why would this affect the gauge cluster"?
Bad grounds can affect everything. If it acts up and you have a voltmeter, connect one lead to the positive cable and start with the other at the negative terminal. Check the engine block, body, frame (if separate) and other points on the car. When you have no ground there will be no current reading (or a very low reading) on the meter. Otherwise you should get close to a battery voltage reading.
Printed circuit boards can get bad connections too, they can usually be spotted with some decent magnification. regards Mech |
Starting with the simplest thing first, I just followed up with Nemo's suggestion, and charged the battery. The only exception is that I'm going to have to got to Autozone to have the battery tested. For now, it would appear that the entire gauge cluster is operating normally. Thank you all for your input.
Seems to be common on that generation of Civics for the gauge cluster to go out because of bad solder joints on the cluster circuit board, as Old Mech said. The one on my '94 Civic also went out. However, a bad ground would be a more likely explanation for all things that you'd mentioned going wrong at the same time.
Turn on the headlights, if they don't kill the battery in an hour it's barely OK. Two hours decent. 3 hours just about new condition. I know this from forgetting to turn mine off at the golf course. I've seen batteries die in less than 20 minutes after being fully charged and they passed load tests. Too many customers called the day after charging and load testing to tell me the battery was dead the next morning. Pop (93 in 4 days) replaces his battery every 3 years. They always tell him it's fine. He tells them "use it in YOUR car". regards Mech |
I've seen them last 13 years and Frank Lee has one that is 20 years old. At 93 Pop can buy a battery without a second thought and a broken down car is the last thing he wants to have to handle at the wrong place and the wrong time, which could get him killed.
regards Mech |
The symptoms were that my headlights and dash lights were noticeably dimmer and the radio was dying out as I was driving. (My car has a cable drive speedometer, so that was unaffected.) A new alternator was the cure. |
I just got the battery tested at the auto part and was told that the battery is good; but it's at 49%. Earlier when I said that I had charged it, I should have clarified by saying that I had "jumped" it with my other car. At any rate, I'm really starting to think that's all there was to it, thankfully.
As forward thinking person, just in case it would in fact has something to do with the gauge cluster, would there be an aftermarket gauge cluster that I could buy new? |
I used to test them the same way. Charge it an then turn on the headlights and see how long it lasts. After repeated calls about dead batteries after load testing and charging, I stopped testing them, charged them and then turned on the headlights.
If your headlights will not stay bright for a hour minimum, get a battery. You can read the date code on the battery and if it's more than 4 years old and you fully charge it and it will only keep the headlights bright for an hour, you need a battery first. Not going to try to tell you it will solve all problems, but without a good battery you are wasting your time with ANY further diagnosis, and throwing any more parts at it is wasting money. You may be able to repair the circuit board on the dash, and you can test the charging system with a voltmeter. Personally I would not do any of that until I was sure the battery was good enough to do it's job. That's step 1 from 60,000 hours experience since Nixon was President. regards Mech |
