Splitter for thé leading edge of a car hood?
1 Attachment(s)
I’m currently fixing a rearend issue but my next project is a grill block to cut down on the air through my grill.
I already have an air dam below the bumper that is sealed back to the radiator core support. Since my car is old, the grill is pretty vertical. And the leading edge of the hood is basically folded back at some degree less than vertical. So I”m thinking what would be the benefit/detriment to have a small splitter like extension along the leading edge of the hood, for conversation, say 1”. Would it not affectively lengthen the hood slightly and force more air from the grill off the side of the car? And would either of these be good or bad? Pic of the hood just FYI. |
As points of reference, I would suggest the 2nd Generation Golf, where they rounded off the earlier square edge ....just enough. And Smokey Yunick's never-raced car. motortrend.com/vehicle-genres/12q3-1966-chevrolet-chevelle-grand-national-race-car/
leading edge
1 Attachment(s)
The air is already displacing out ahead of the car as if it had some phantom nose. It's referred to as a Prandtl line of discontinuity.
In the Volkswagen photo link you can see this. You need an uninterrupted pathway for these streamlines to get over the leading edge of the hood. A splitter would look like a 'wall' to the air, with the potential to create remarkable separation and turbulence. The air 'knows' what to do. I recommend that you abort any attempt to direct it sideways, and just let it go where it's gonna go. That raked-back radius on top of the nose ought to be enough for attached flow. https://ecomodder.com/forum/member-a...ing-follow.jpg |
Thats why it's called flat plate equivalent in aircraft circles. OTOH, trailing vortices suck and can get minimized.
The top edge is fine. The purpose of a splitter is to provide a horizontal shelf for the air to exert downward pressure on.
I assumed fiberglass, steel is harder to work with. But you do see the problem so that's good.
I also won’t extend the hood edge out any based on all your guys advice. |
Tell me about it. I have a set of fiberglass reproduction Foxcraft fender skirts with the same problem. The clamping mechanism impacts on the end of the axle,
