EcoModder.com
-   General Efficiency Discussion (https://ecomodder.com/forum/general-efficiency-discussion.html)
-   -   Spray-On Insulation/Finishing Interior Surface? (https://ecomodder.com/forum/showthread.php/spray-insulation-finishing-interior-surface-2181.html)
Wayneburg 05-06-2008 04:54 PM
Can anyone here recommend a spray-on sound insulation that can be used as the exposed layer on the entire interior of a car?
I'm interested in gutting out the interior of a Metro or Swift to lighten the weight of the car, but I still want to have some sound insulation and somewhat of a finish on the interior (for the significant other's sake at least).
Thanks for the help
dremd 05-06-2008 06:14 PM
Spray on Bedliner works well, but carpet glued on works much better for noise . . . . Worse for Water . . .
Wayneburg 05-06-2008 06:53 PM
Thanks. I'm looking into bed liners now. One thing I'm concerned with is making sure whatever product I choose must have low levels of VOC. I mean I will be in a closed compartment with this stuff. I don't want to get sick.
dremd 05-06-2008 06:56 PM
If you do bed liner DEFIANTLY USE A GOOD RESPIRATOR the stuff is POTENT.
I've used it on several interiors before, use a respirator, only spray for 3~5 mins, open doors, use a fan and you are ok. <- Not Official OSHA Advice
Wayneburg 05-06-2008 07:03 PM
Good advice that I definitely plan to follow. But, I'm also concerned with this stuff continuing to offgas long after it has dried. If it contains VOC's I want to make sure it's at least at a low level. 150 gm/l or lower.
dremd 05-06-2008 08:20 PM
I couldn't give you any specs, but I can say that it does not smell after 2~3 hours. . . .
