Stage 1- cut
1 Attachment(s)
I sent the E-Pod to a car body shop to cut about a 9" x 11" chunk out of the "whale tail" to get the dead 36V battery out. A lithium would cost over $600., so I will see what I can get.
Bye bye shiny side...... |
wut? :confused:
Then moving the seat back cracked it- lots of glue, bracing (drilling right into the main frame) repaired the seat so nothing is easily removed- it is like a permanent hollow triangle now. Dead battery with no way out. But with a big hole in the side I can replace the dead battery. No more smooth unfettered shell any more- I will just hinge the cut out piece of fiberglass/kevlar or tape it up. |
No lithium- way too expensive. Might take a while to see what else Batteries Plus or some other dealer have.
(sniff)
The poor wee bairn. I hope it's back in service soon. If the Lithiums work out well for you in the E-Pod, will you be upgrading the City-El next when finances allow? A City-El at nearly double its original range would rock! :) |
No Lithium?
:( Sorry... |
3 Attachment(s)
That City-El has new brakes coming and it would cost a fortune to put lithium batteries in that, but that would be terrific! I saw a picture of one with all 4 nicely factory done, so I know it is do-able! |
Maybe someday soon-at least you wouldn't be saving up for some of the full-sized EV conversions i've seen, so there's a chance you can afford a Lithium City-El eventually. Could you imagine the bill for a Tesla pack replacement? :eek:
Good news BTW- I just found three old Touring Bikes in one of Grandad's old barns in varying states of repair! Enough salvage to create a Trike of my very own... Assuming I knew how. Assuming I can borrow a welder. Assuming I can learn to weld. Assuming I can learn Suspension, Steering configurations, Brakes and what the heck a Shimano cartridge does... Life's an adventure! :p Maybe I can at least fashion a Cartbike: How to Build a Cartbike Imagine one of those as an EV...heh heh heh. |
1 Attachment(s)
A bolt on motor would be fairly easy, but another project is not exactly what I need right now! :D It would make a nice fair weather trike. The photo is deceiving - it is HUGE! |
It took a big hole to find out a connection came loose, the wires are very stretched. After all this time it ran fine for a block then slipped right back out. Again, fine. Why it lasted over a year before doing that is a mystery. The E-Pod is back in the garage!
