Stalled while Neutral Coasting
Im not too familiar with EOC
But I was EOnC (Engine On Coasting) down the hill when the engine shut off on me It happened at the end during a turn when I was going maybe 10 mph or so I didnt know what to do. So I coasted to a stop and then started the car again. Luckily only one slow driver was behind me and he went around when I flashed the hazards. Is this different than EOC? Is there a way to restart while still in motion. |
Your Tracker should restart while in motion, if you're in neutral. (You were already in N, right?) Not strictly necessary to come to a stop first. Just turn the key.
I used to teach "rolling re-starts" to new drivers as part of a defensive driving curriculum (driving instructor as a part time job when I was going to university). We would intro the concept, explain how a stalled engine affected steering & brakes, and how to bop the gear selector to N to attempt a re-start if it was safe. Then try it out on a quiet road (I'd reach over and key off / on to kill the engine). |
Yeah I was in neutral
it cuts off like that sometimes when I coast slow in neutral Ill just restart |
You should find out why it's stalling. Does the check engine light come on when this happens?
My check engine light is always on, been like that for years
Get the codes read.
Also, is your fuel level low when it stalls out? 92-93 Bonnevilles stalled when going around sharp corners when the fuel level was low. |
I know the codes (but not offhand), might be egr but thats common with my car
Its not fuel level as Im almost always at least half tank |
Yeah, an EGR problem can cause stalling at idle.
EonC is just the same as idling while rolling. Get it fixed! A check engine light can cause the ECU to employ a backup fuel map that is richer, uneconomical, and unlikely to stall. I know my Subaru loves to idle high when it's really cold out, or when the CEL is on. |
I know how to fix but I have to remove a lot just to get to it. If I went to a shop they would probably charge a couple 100 Ill probably leave it. Ive actually done it a couple more times. When Im going super slow, ill shift to neutral and itll cut off Its almost like an automatic EOC. :D |
Good advice on the 'rolling restarts' Metro. I use that in my daily driving, and I must say it's a pretty nice little boost. I usually will try to time lights so I can EoC up to them, and then restart the car when I need to start accelerating again.
