EcoModder.com
-   General Efficiency Discussion (https://ecomodder.com/forum/general-efficiency-discussion.html)
-   -   Standardized Gradient for roads (https://ecomodder.com/forum/showthread.php/standardized-gradient-roads-7320.html)
thorpie 03-03-2009 06:00 AM
1 Attachment(s)
Hello
I have written a document briefly outlining the case for standardizing road gradients.
I believe that a standardized road gradient will be the greatest single contributor towards a sustainable transport system. It will permit minimalist vehicles to be manufactured that simply meet a standardized functionality.
I am attempting to promote discussion of this subject. Any comments, or suggestions or assistance in disseminating the content as widely as possible, will be appreciated.
dcb 03-03-2009 06:47 AM
My "standard gradient" would be a large sinewave, so I can constantly pulse up and glide down :)
Oh yah, and all stops would be at, or just after the top, and all drive-throughs would slant forward.
thorpie 03-03-2009 08:17 AM
A sinewave gives a constantly changing gradient which is not optimum. To keep a consistent speed you want one standard down gradient and one standard up gradient!
dcb 03-03-2009 08:24 AM
I am using sine wave just as an example. You need to smooth the transitions though, suspension compressions = lost energy.
And I don't think constant speed is necessarily optimal, while ascending sure, but not while coasting.
thorpie 03-03-2009 08:47 AM
It depends upon whether you can utilize the engine's output most efficiently. Utilize engine only when it is running at minimum BSFC.
Which you can only design to with a standardized gradient up, and a standardized gradient down! (excluding wind!)
dcb 03-03-2009 09:03 AM
Well, technically you would need a standardized car too if you are going off of bsfc maps, and a standard rate of ascension, and probably a standardized fuel.
Plus driver (re)training to utilize the new geography. And some assessment of when the money/fuel used to remold the landscape would reach the break even point based on anticipated traffic.
thorpie 03-03-2009 09:18 AM
Exactly. As with any other standardized product, which allows universal interconnection and allows minimalist design to meet only the standard's requirements.
The alternative is to keep requiring over-engineered vehicles to run on over-engineered roads. This equates to allowing builders to use any number of electrical socket types in houses and requiring the manufacturers of electrical equipment to provide a number of different plugs on their products.
robbiewt 03-03-2009 09:49 AM
1 Attachment(s)
Down hill all the time!
http://ecomodder.com/forum/attachmen...1&d=1236091405
But that's not possible.
Even the slightest climb can hurt gas mileage. It would be very hard to make roads go down hill in both directions. Therefore, a stretched wave would be best for traffic in both directions.
jamesqf 03-03-2009 12:10 PM
Seems to me there's already a standard gradient limit on US highways. At least, it's fairly rare to see even a 7% grade on a main highway. The few places I know of that are steeper have major topographic constraints.
CapriRacer 03-03-2009 12:40 PM
I am confused
I am confused by your proposal.
It almost sounds like you are advocating a different grade coming into town than leaving. That can't be right, can it?
While you don't mention a limitation, you must not be discussing mountainous terrain. I know of some roads where it would take 30 miles of approach road building @0.7% just to get to where the road starts up the mountain. Surely you didn't mean that, did you?
You seem to imply a connection between mass production and road building. I am under the impression that roads can not be mass produced - that they are built "in situ", that is, in place. What am I missing here?
