EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   stationary lift (https://ecomodder.com/forum/showthread.php/stationary-lift-38931.html)
aerohead 12-23-2020 03:28 PM
stationary lift
Now that the other thread is closed, I wanted to mention, in passing, that no aerodynamic forces were ever implied, nor ever mentioned.
It was just a thought experiment, as I've done in the past with other subjects.
The premise was to illustrate the difference in static loading of the axles, when any given vehicle is operated below its rated GVWR.:)
