Is it still progress?
I had this thought today;
Suppose I have a car that gets 15 miles per gallon of gasoline. I trade that in for one that gets 30 miles per gallon of gasoline. But then I switch from using gasoline, to using E85 ethanol. I lose 10-15% mileage, yet I'm still getting higher mileage per gallon of fuel that I was with the old car. The question: Is this still considered progress? |
yes. First, it's way better than 15. 2nd, it's an alternative to gasoline. There are multiple sources of ethanol. Not just corn.
There's only 15% gas in E85, so you've reduced your gas-use to 8.25 to 8.6 % of what you used with the 15mpg guzzler. |
If I have a truck that gets 17, mod it so it gets 7, then mod it again so it gets 9, is that progress?
Argonne GREET Model |
Going from using 1 gallon of petro for 15 miles, to using (assume 30 mpg E85 so math is easier) .075 of a gallon of petro for the same 15 miles, winter blend of E70 would use 0.15 gallons of petrol.
Check out the Buick Regal Turbo, one claim of 5-8% MPG drop using E85. I saw somewhere a claim of equal MPG on it yesterday, never heard of it till yesterday. Too pricey for me, but I think the techonology will work down to the Cruze. (EPA rating are the nomal 1/3 third off). 2011 Buick Regal Turbo features flex-fuel capability |
If you consider it progress to switch to a more costly fuel that delivers less performance, then you have answered your own question.
My definition of progress includes concepts such as lower cost, higher performance, and with respect to the environment, benefits which are proven and highly predictable. Ethanol will not be fueling our vehicles 30 years from now. It is not the fuel of the future. It will be fueling people for many years though, and I'm saddened that I cannot purchase it so cheap for bodily consumption. |
My thoughts on ethanol;
~The cost of E85 could be $1 less if the special tax was removed from it. Locally it was 50¢ cheaper per gallon (than 93 gasoline) a few years ago. ~I'd rather have switchgrass- or sugarcane-based fuel than corn. Brazil's been using it for years. ~Alibaba and Habib don't control it. ~I could make it myself if I needed to. (same with biodiesel) ~It's renewable, sustainable, a multipurpose fuel. ~Imagine keeping the US fuel production AND consumption on this side of the planet. CA/US/MX all sharing energy independence. A meteorite can crash down on an oil pipeline in Iprakistania and no one here would have to take a bus to work because of fuel prices jumping $2 overnight. lol Quote:
People always get so hung up that Ethanol reduces MPG, but the fuel has less energy in it so who cares if you use more volume, you are still using approximately the same energy content..
There's the real benefit of E85. Unfortunately, Joe and Uncle Sam decided to produce ethanol from corn. |
Here's the real problem.
http://imgs.sfgate.com/c/pictures/20...mn_biofuel.jpg |
Nice. Now show us the cost of gasoline in a nice biased graphic like the one above.
All the SOLID info I've seen indicates Patzek is waaaay off the mark.
Ditto Frank,
When looking at these Ethanol studies you have to look at the results of a bunch of them, not cherry pick one that may have a bias towards either the pro OR con side. |
He shows CO2 thrown off from distillation but does not show the CO2 absorbed by the corn. |
tjts has been here for years and has had to have participated in ethanol discussions before. So others refuting nonsense like that posted above is not a new thing. His agenda is preventing him from considering all the data. :(
Oil Spills and Disasters - Infoplease.com The Real Cost of Oil: How much are we paying for a gallon of gas? HUMAN RIGHTS AND ENVIRONMENT IN TABASCO http://tribalenergies.com.au/wp-cont...oil-spill1.jpg http://www.oilism.com/oil/wp-content.../oilspill2.jpg http://blog.weblayers.com/Portals/70...-oil-spill.jpg http://cdn.radionetherlands.nl/data/...il-Nigeria.jpg http://watercentral.files.wordpress....il-nigeria.jpg Kenya gasoline explosion kills more than 60 in Nairobi slum - Los Angeles Times Gas explosion: Brooklyn Park man has life-threatening burns - Baltimore Sun How's that? |
The GREET figures offer no support at all for the contention that producing a gallon of ethanol consumes 6 times the energy that it contains. |
...yes, it's still progress, but only if the definition of 'still' is assumed to be 'stagnant' (wink,wink)!
There are more & better ways to make ethanol than starting from corn.
Just like what happened with biodiesel starting out with rapeseed oil, better crops have been found to produce ethanol. |
On the farming side, most of that 1300 lbs of fertilizer is NOT necessary to grow corn. The 5300 gallons of water is rain, and is going to fall on the fields anyway, and be used by whatever plants are growing there. On the production side, all that water is NOT waste, it's just water which can be re-used, or put to other purposes. For the heat, any sensible producer would build their ethanol distillery next to a power plant, and use the waste heat from it to do most of the distillation. And of course, the mash that's left is a protein-rich animal food. And of course the whole thing about the CO2 given off in fermentation & burning of ethanol is worthy of being accepted as denialist propaganda. Since it's part of the ongoing carbon cycle, it does not increase atmospheric CO2. |
But hydrogen? That is the fuel of the present, contained in petroleum, vegetable oils and alcohols. That is ICE fuel, and is the root of all the current problems - renewable is good, but electrical or mechanical transportation energy gives us the reduced/zero emissions, control of pollution and greater efficiencies we need to move forward in a positive way. What you may be referring to with "hydrogen" is gaseous, and it flat sucks as a medium for energy storage. It leaks, it explodes, it has horrible energy density and requires stout heavy hardware (high pressure and cryo) to use effectively. It's a costly boondoggle, supported only by petroleum interests because it's cheap to make hydrogen from coal and natural gas. The best way to use hydrogen is bound with carbon in renewable liquid fuels. |
15MPG on Petrol = 2254 Wh/mile 30MPG on Petrol = 1127 Wh/mile E85(assuming 85% Ethanol/15% Petrol) has 82,294 BTU/Gallon while Petrol has 116,090 BTU/Gallon. So E85 has 71% of the energy content of regular Petrol. Source: AFDC Energy Convert BTU to watts. E85= 24,102 Wh Petrol = 34,000 Wh If you lose 15% range(I've heard this is typical on non-FFVs and older FFVs alike) than that is 25.5MPG. So your energy consumption per mile would be 945 Wh/Mile. That is a reduction of 57.7% of your original consumption. I believe it's progress simply because that is a huge reduction in overall Fossil fuel consumption and it significantly reduces energy consumption. The only problem is how much does it cost you per mile? Prices are still too high here, but lately Ethanol prices have gone down while Gasoline is going up. Tjts, that chart is only useful for purely scientific purposes. A more practical comparison is how much Corn Ethanol costs per unit of energy compared to regular Petrol. Corn Ethanol was cheaper in the near past, before the Biofuel mandate, and more recently the market price of Ethanol has dropped but it's not sustainable. redpoint5, Ethanol is infact a more efficient fuel than Gasoline, it is simply not as energy dense. Strangely, Octane for blends from E50-E85 is about the same, 95 1/2 octane AKI, still better than pump gas at 93 but not what you'd expect. Plenty of the hotrodders, tuners, and engine builders swear by it. I've heard E85 is just shy of C16 leaded fuel but either way it is vastly underutilized in a FFV. BTW, according to federal law it is ILLEGAL for manufacturer's to test MPG on anything but test grade Gasoline. The EPA MPG numbers are based solely on energy content, not on real world driving with E70-E85. EPA FAQ |
...and that "...test grade Gasoline..." is 91-octane (mid-grade), not the typical 87-octane often recommended for most engines! Talk about "gaming" the EPA fuel-economy test system!!!
The thing is they only ever use 100% Gasoline. So even 10% Ethanol you can expect up to 3% less MPG than whatever they tell you. And that is the federal law...:rolleyes: |
...go to the EPA website, they state the mandated use of 91-octane gasoline (unless higher is required)...note that 91 is basically 'midway' between 87(minimum) and 93 octane.
Edit: I looked around and they didn't* mention such a thing anywhere that I looked. Infact they made a point to emphasize not to use more octane than is recommended. The Low Down on High Octane. |
...from slide 11 of this presentation:
http://www.arb.ca.gov/msprog/levprog...1/alliance.pdf ...it shows, in the right column, the current Federal (EPA) "test fuel" requirements. Note that AKI is always slightly less than the RON number, hence AKI = 91 octane, from RON = 93 octane. |
Also, as a point of order: 91 octane (AKI rating) is the highest that is available in many areas--including all of California--without getting "race gas" which is technically not legal for use on the street.
EDIT: And AKI rating is always less than RON, AKI is the average of RON and MON; the MON rating of a given batch of gasoline is from 8-10 points lower than the RON rating of that same gasoline. So the AKI rating will be about 4-5 points lower than RON for most gasoline. -soD |
...back to my 'original' point, which is:
1) EPA tests with 100% gasoline, not E10 <--- stated by others. ...and... 2) EPA tests with 91 octane fuel, not 87 octane which MOST engines are specified to use by their manufacturers. ...and, because most current engines can "adjust" operating conditions (ala' knock sensor) to achieve "optimum" results with varying fuel charactoristics (and thus performance)...the EPA tests are using higher-milage 'capability' 91 octane, not the lower 'capability' 87 octane that most people follow. |
I don't see how that means they only test with premium. :confused: |
...directly from the title of chart #11:
Current ARB and EPA Certification Fuels |
What I meant by less performance is less energy content, as you pointed out. People are primarily concerned with how much a tank of fuel costs and how far it will get them. In this way, petroleum is more efficient, otherwise we would all be driving E100 cars with high compression ratios and turbo chargers. Maybe one day ethanol will be relevant, but this is not that day. |
Slide 10 you can see they are proposing the use of 91 octane for both. Quote:
Which one is more economic depends on the market and how efficient your vehicle is. For example, in the Midwest, Ethanol rack prices have dropped to <$2.50 a gallon while Gasoline is well above $3. Here I can buy E70 for $3.09 while Regular Gasoline is $3.59. If Ethanol drops 10 cents or Gasoline rises 10 cents then E70 make economic sense since I will only lose 15%-20% tops. Spring through fall has more Ethanol than winter so prices can actually drop leading up into summer. :D But in places like Minnesota, Iowa, the Dakotas, etc they can get E70 for <$3 and Gasoline is the same. |
Specific example: operating a turbocharged engine on both higher octane & higher energy content fuel produces better FE because the computer and sensors allow the engine parameters to be "optimized" upward to exploit ALL the benefits of the higher energy (mpg) and octane (advanced idnition timing)...that's "gaming" the system.
Also, notice that ALL tests are done with NO electrical loads, save those during A/C tests only...but, YOU and I do drive at night, don't we? |
