12-12-2025, 03:01 AM
Stop the desert, get free power?
https://www.youtube.com/shorts/es31ThrRZw8
To appease someone in power this method of bringing the desert back to life will likely also work if you just put up some well placed dummy plates. What's not to like?
The Following 2 Users Say Thank You to RedDevil For This Useful Post:
12-12-2025, 12:45 PM
Yeah but, how do you get rid of the sheep?
I grew up on a farm with 30 head.
12-12-2025, 01:31 PM
High Altitude Hybrid
Tacos. How else?
12-12-2025, 02:33 PM
They omitted half of the story. The sheep don't just mow the grass, they fertilize it.
..Without freedom of speech we wouldn't know who all the idiots are. -- anonymous poster
..The quickest way to double your money is to fold it iin half and put it in your back pocket -- Will Rogers
12-12-2025, 03:39 PM
Maybe sheep are valuable in China?
Most people seem to like lamb, but I could never get over the smell, and therefore the taste.
I consume a lot of beef, but you probably don't want those around your solar arrays.
12-12-2025, 04:00 PM
IDK, just get the panels 6 feet off the ground.
Make that 20 feet if you'd like to herd giraffes instead.
12-12-2025, 04:08 PM
Once the land is sufficiently undesertified it can be used for agriculture.
Many crops need way less sunlight than they get in an open field. Most plant species originated in forests where lighting is dim for the tree canopy overhead and humidity is generally much higher. Our open fields overpower and dry out our crops, so adding shade and reducing evaporation helps them.
Surprisingly crops like potatoes have up to 80% higher yield per acre when raised under partial cover from solar panels compared to no coverage in the same location.
12-12-2025, 05:01 PM
There should be a modular quick connect, disconnect standard for solar panels instead of every rack being bespoke. 1 or 2 buttons that get pressed that release the electrical connection AND the panel from the mount. Once that happens, autonomous robots can pull malfunctioning panels out and replace them with new/repaired ones. The malfunctioning panel is brought to the service center for repair.
Most of the cost of PV installation and maintenance is because the industry treated it like building a house.
12-12-2025, 07:37 PM
#9 (permalink)
People eat giraffes?
centraloregonostrich.com
Central Oregon Ostrich - Ostrich, Farm
Ostrich is a nutritionally dense red meat that is environmentally friendly. Low feed consumption, prolific reproduction, and a high density nutritional profile make ostrich an excellent red meat alternative for health conscious consumers.
superiorostrich.com
Ostrich Recipes - Superior Ostrich
Nov 23, 2025 Discover The Superior Ostrich Recipe Center! Explore delicious, at-home recipes featuring ostrich meat and eggs. From grilled ostrich steaks to deviled eggs, enjoy our nutritious, creative collection. Submit your recipes and join our culinary community today!
Highland Farm
Ostrich Eggs - eat-better-meat
Ostrich Eggs Typically available May through September Our ostrich hens lay eggs seasonally from spring to early fall. Each hen lays an egg every few days, but will sometimes stop laying for periods of time due to weather or other factors. The eggs are pretty amazing!
12-13-2025, 01:13 AM
#10 (permalink)
I'm sure they're edible.
Most of the housing is expensive because the industry treats it like building a house.
The Following 2 Users Say Thank You to Ecky For This Useful Post:
