A straight sided fairing ?
A question for those who know such things. I've been thinking yet again about the ill effects of a tapered fairing... that lovely classic shape which has the unfortunate effect of flicking you around if the wind off a truck or around a building hits unexpectedly.
How about the flat sided fairing, like a pyramid , wider at the front but with the leading edge low tapering up but the maximum width at that point then coming back to a reduced dimension at the extreme back? This is rather hard to explain but my scanner is dead, a drawing would be a better way of explaining. This photo of the Dome racing car was the inspiration for the idea. Flat sides ,thus no lift ! No side lift is what I'm after. http://i1062.photobucket.com/albums/...ed/Dome%20.jpg |
The vertical fin area gives a surface for the wind to push from the side. To minimize lift and reduce side wind load we use a curved body. The cross section is like an inverted egg with the larger radius at the top.
I understand the theory Grant but that egg shaped side generates side lift that can be deadly. The flat side would have the same surface area for the win to push against but would not generate side lift if the wind is off to the side.
Side lift? referring to the reason nascar, and land speed record cars use roof rails? adding side skirts might be easier to do, help just as much, and have less chance for unintended effects.
Edit: nevermind, I'm a dumbass stuck in 4wheel mode |
What would the side skirts do mc ?
Side force elimination
Hi Peter, I'be followed your previous postings about motorcycle body designs and I get where you are coming from
Unfortunately there is no easy answer to your quest (I've been looking for it myself) because of the complex nature of "side lift". Lift has two components, Newtonian and Bernoullian, and you are searching for a means of eliminating the side force ONLY using Bernoulli's principle. Even if you were able to do this ( as your question implies) it would still leave the Newtonian component, which as it applies to motorcycles is the greater of the two forces. A useful explanation can be found here http://youtu.be/zUehWUoiPHQ Your efforts to reduce sidewind sensitivity should be aimed at reducing the "sail area",and lowering the Centre of Pressure (ie height above ground). This will reduce the turning moment around the tyre contact patches and reduce the lean angle, thus aiding stability. One of the central problems with traditional motorcycle design (ie those that keep the normal hands first riding position) is that a high centre of gravity also implies a high centre of pressure Attempts to enclose the upper body area of a motorcyclist will inevitably result in a large "sail area", high above the contact patches, and therefore a large overturning moment. To make any real progress in this area you will need to consider recumbent riding positions or active aerodynamics. |
Thank you , a great reply .
It seems to me that flat sides would negate side lift almost entirely, that's the Bernoullian component dealt with or am I missing something ? As you say the Newtonian component is the problem that remains and feet forward seems the obvious response. I think a Honda CT110 would make an ideal basis for such a bike, for me at least. There is a bloke who posted an excellent thread on his Honda 90 version of feet forward and I've been thinking about it ever since . This basic design should work but if I add a Vetter style rear section I still have the curved life areas . This bike. http://i1062.photobucket.com/albums/...20P3100450.jpg |
Perhaps another way to solve this would be to get a front trike. Like this: Trike Gas Motor Scooters 50cc 3 Wheels Moped
http://www.scooterdepot.us/media/cat..._d50tka_11.jpg It's low and the double wheels in the front greatly improve stability. Don't know. |
Interesting but not available in Australia in that form or at that price !
"Total Price: $1,758.00 + $399.00 Shipped!"
Normally, when I have seen people say "$x shipped," they refer to the cost, including shipping. $399 for shipping? It kind of seems that if you want an Elio, you need to purchase one of these and build a body. Lower the seat like this guy: 214 mpg with DIY aerodynamic fairings on a Honda 125cc motorbike |
The idea behind the egg shape is that the shape will generate down force instead of lift since the air moving over the smaller radius will have to move faster. Stall strips on the nose help too. Don't take my word for it, ask the Vetter challenge people.
I was reading about Alan's results and they are great, he reported no trouble with side lift either .... perhaps they were no 18 wheelers on his course ?
http://i1187.photobucket.com/albums/...r/SAM_0104.jpg
See the 1960's Indy cars prior to wings. http://8w.forix.com/indy/mg-indy63.jpg While the boxy Chaparral 2J used vacuum power to generate down forcedata:image/jpeg;base64,/9j/4AAQSkZJRgABAQAAAQABAAD/2wCEAAkGBxQSEhUUEhQVFBUXFx8UFxcUFRwYGBoXGRoXGBcYFh gdHSggGB0lHBcYITEiJykrLi4uGB80ODMsNygtLisBCgoKDg0O GhAQGy0kICQvLSwtLC4sLCwsLywsLCwsLCwsLCwsLywsLCwsLC wsLCwtLCwsLCwvLCwsLCwsLCwsLP/AABEIAJQBVQMBIgACEQEDEQH/xAAcAAEAAQUBAQAAAAAAAAAAAAAABgEDBAUHAgj/xABPEAACAAQDBAUFCwgIBQUAAAABAgADBBESITEFBkFRBxMiYX EUMoGRoRYjQlJTYpKTwdHSFRdUVWNylLEkMzSCotPh8ENEpLLC ZHN0g4T/xAAaAQEAAwEBAQAAAAAAAAAAAAAAAQIDBAUG/8QALhEAAgECBQIEBgMBAQAAAAAAAAECAxEEEiExURMiFEFhgQV xkbHR8CNCofHB/9oADAMBAAIRAxEAPwDuMIQgBCEIAQhCAEIQgBCPLuACSbAZkmM U7Uk/KJ64AzIRhnakn5RPXFPyrJ+VT6UAZsIxBtOT8onrjLgBCEIAQh CAEIQgBCEIAQhCAEIQgBCEIAQhCAEIQgBCNTvBKdwkuVPaQ74g pCkgkKTY5WFrX1F87d2lkMxxgVpa7gAOGBBBZioIztYgi2oQ3y BsBMIRCVr54KYNo07KQpONBjKtiYGwzN+yAMshrfM5Dzavqx/TJWNgWB6g4cKAYza175N69IAl0IjdJXsJ3bqpXVmzBCcLm8tLA KVGpOL1DnG3O1pANutl3184acM4AzYRhJtaQSQJsu4vcYhcYRi b1A3PdD8rSMvfpeenbHf9xgDNhGM20JQAJmIAdO2M7kgWzzzB9 UVpq2XMv1bq9gCcJByN7ZjwMAZEIQgBCEIAQhCAEIQgBCEIA12 8c3DSz25S2PsjjtRvB3x1ffh8Oz6o8pLn2GPmp67vi0VcE8G8B 5+2PP5ezzPtiELW98UmVffF8pBPqfbwxDO+dvbHcY+VqOq7Qz4 j+cfVMUkiRCEY0oN1j3N1sLDlr3dx5+iKgyYQhACEIQAhCEAIQ hACEIQAhCEAIQhACEIQBYnTkDorEYmJwXGpAJNjwNr+2NHNDlR nSFyVKlgM04GxzzwqPQe6N9Mp1ZlcqCyXwniMWTW8bRHXopjH+ z09wcI7WK6gkjPLDxyzsYA9lDe4NGUzGKwuCQTKvwGdotWZsj5 GxYKJZwjExxYmW3LAXGXO+WcZHUMkvAKeUQxClFYZgEkanO2be nTjCVJnJnLpJSYTdRjGfYtlbIZlh4eMAeaYXeWJq0dsHaCgYl7 IXsX+DcAeFuWezUUzdodSfgYuz8HIrfu5Rrl2YeyPJZKh2LzLE WGZuRpdiLZ/OPLNKo3eWVeklrdvNMzFqbsxPO6qecAbES6ZSMpIJuoyUE3BBX vyVhbuMeWk0vFZPAaL8K4X1525xrJWzjZ70aWIxBesvdyxB428 1jnloRxEeTs51WwpJbCykqJpXta6km4BZ78734wBuJlLTthuko 5BVuFOQzAHdxtF6hkygLyQgBtcpaxsMsxrkfbFiTsWQrYxKUMb EnMkldCTxP8AOMijoklAiWuEE31Jz9MAZEIQgBCEIAQhCANXtL eKlp2w1FRJkk6Ca4Qnwuc4w/dxs79Opfr0++N3UU6TFKzFV1OqsoYHxBiE7c6JNmVNyJHUMfhU 7YP8Gaf4YkG9G+uz/wBOpfr0++K+7LZ/6bS/Xp98ci250CTVuaSpSYOCT1KH6S3BPoEc/wBtbibQpL9dSzcPxpa9YlhxxJcD02ibIHfd/t7qKZs6rSXV07u0h1VVmqWJIsAADmY+ZvKDeLAaF4slYgzpFQY 9TqkxjSY9zREg9yK4hhnxj60XfGgP/O0316ffHx8wisiUWYKoLMcgqi5J7gMzFXqD7B92FB+m0316ffF lN8KDG39NptB/x0+d3x86bF6MNp1ViKcylPwp56sfRPbPoWJ/sPoCXI1lUSeKU6gDv7bg3+iIrZEnUG3z2eNa6l+vT8UbHZu1ZF QuKnmy5y/GluHHrGUR/YnRxs2lsZdLLZh8Ob761+fauB6AIlaqALAWA0AiAVhCEAIQhAC EIQAhCEAIQhACEIQAhCEAYtROcTZSqoKNixtxWwuts87nK1j6L RHJVCbL/Rgwzu3Xdq5OQBXQA3yz4cYkk+hR5kuawOOXiwG5AGMWa4vY6DX lEXn0aEIVpZ5w2BRiQLAmzaHE2VvDllAGXTyDLs8ujKTFYqoab e4tYvkTcdo62OR42vsvyhOJmWkEBcWEs2T4fNtYE2bL26xq6iU rFveaq7rhxKbFQGU2udCSBnnpyAsmIuEXl1KYUL3U64grEEkZk FcNv9iQbA7UnWJ8lfW1sa34Zju19Q9FE2pPJa1MwAViMT2JYXw iwXRrDPvjVzZKDDeXWgsRobHLGBex1tfvOV7xSZKDIg6qrCFcB AIBCoiAXW1s76D4ptqQQNwm05tjipnBAU5EEG7AHDlfIG+Y4Hu J90VfNfBikNLv52JvN7BbgCD2hh1GvGNRNwLdilWRMs2AKDZnb rLgXsLFfbqeGVQUi9dgBqryxmzt2G7IUC/wjZtRbNYgEghHmWlhbM+JufWY9QAhCEAIQhACEIQAhCMeVMIyf Uk2I0IubDuNrQBkQhCANJtrdGiq/wC0U0qYfjFQH+mLN7Y59tzoIpZlzSz5sg/Fe01PRow9Zjpe0do9TMlhvMa4Y8j2bHwzjG2zWzVxdTYBFLMSL 3IBNvCLqLKOaRwTavQ9tKnPvaS6lb6ynAbxKvh9hMbHY/QrWzrGoeXTLyJ6x/oqcP8Aijtk6fNlyzMmTEVVXEzMAAAMySeAjDO3LH+0SNUXh503 +qGurcOcWs+UV6q4ZFti9CdBKIae02pbk7YE+ilj62MTzZOwqa lFqeRKkj9mgUnxIFz6Y08/eRVB/pNPkHPDSV/W8fg8Yy0q6qyMOrZXtY4TaxF1OvH7YjI+UOquGb6Eata2ePOkg 96t9hH2xcXay/CSYvit/wDtvEZJFupE2EWZz37K6kZ/NB4358oxPytLc4UmKDxLG1u6x1bu4ceAObJUAdnPje97nmTxir TRZNMpSycCKgJIVQt21IAtn3xdhHl3ABJIAGZJyAHMmIJPULxG tp70AEJIBd282yli3fLl5Fx88lU44jpGt3Gq5r1M0TS1/JpLEEjJzMqA17ZXyFyIE2JvFGYDXKMDbm0RTyHmkXIsAObMQqj 1mOQbZ21MaaSZzM/M4Ta/BVIIUeEaQpuSuZuaTsduBisch3O3leTNUNMJlMwR0NsIxGwZQB ZSCc7ax16KyjlLJ3EIQipIhCEAIQhAGLPrMM2XLwscYY4houG2 R8bnuy7xeMyJktFYk1YxETCVux1OQZAGIvMscsip5RMIiRmqWI 8smg2BIKvlkBcZi2aXz58ibgXJ9ail+seq4PYIeyEAUWYXFyc7 cb6QqZktppmM9Qtml5KAAfhgAZkg9VcjIm6juNZc5XmNgrJl5m ShUYqhZlI1JA80ix4NGO+1bkYKtgtxm0k2PE4TYm9jpYDviQXv LUXCpmVFlDKQUNziwjM3scOPLLgM/jXTVIwCrOngEGzBSTaUHLXPE2Ya64RrnGTSU82YCyVb4cRt70o sBZSDfXNSb5axfNBUYABUWYat1YNzcG9icrjhwvlAGtaoU4WE6 oQEFQAMV7HCG43z453y5i/gzi0ovLnTyOsGJitmw2Y2UEjuz0z0yy2bbPqb/wBqt4SV+dzPev0eEXKeinKy3n4lyxAqLmyBTY52JcBvAtxziAa OTtIPjIm1AAGK1luLthWxxG9iQSDlkOBsZHsgDqls5mXucR17R LWOZ0vbXhGZaEAIQhACEIQAizVVSS1LzGCKNSxsIj28G+MqRdZ fvszkD2R+8fsHsjmu2drzqlsU1yeS6KvgPt1jz8R8Qp0+2Or/AMPYwPweriO6fbH/AF/JHbaeerqrqbqwDA8wcxHtlBFjmIhOyN+KaXIlS2EzEiKpsotcA A2zjMHSBSftPof6xtHGUWleSOafwzFKTSpyt8iSFimua8+I/e7u/wBfOL0RRukKkHyn0P8AWMeXvxTk4JJmYn7KqU0Zslw91yMvVyN 1iqL2kijwGJSu6b+ht95pGPDZWJAY5WsM11JIAjVSJtUsoy+rU qVK4ijk2NxqMjYGMDdxNomVOmVtQSyyi0kiXKFmAOIkCXzC+qN 2298iSspJznrGlqzkIbDEoN2sOJ4AcY3deMIdz09TkhhJ1Z/xpt+mpeqaPy6UZM9SiBkZlBPbA7WFhqFNrEa+EYx3Jk48d3vie Z53/EmDCszTzpa5JwXxjCG/1P1zCWsyZiKC4WwA0Jscz4WiagxnCrCo3ld7GtXD1aKXUTV+SI Ho+pcgVJUBFwl8iiEsUPZzDucTfGIEbjaVTNwPgloSjqM3KjIK 98kOhIy8Ys7xb1SKPCJjAuxHZUi4W+bHuAv4xqKff+ixTbs9iw/4Ztbq0EQ69OLs2i8cJXqRzRi2n6GxO3qj9Gl/Xt/kxivvFPfIU6AaFuub0hfede/7dN1QuJqgC4SwIJyZ0YXXvA4HibHhrkV1MTKdZQAfAQnINYhfb aOjPBK9jiyTva5HRtVsNvJJdhwE4/5Ua2urihxCSspdL+UFLk2tn1eXHLvjU7jbMq1riZmLBnjxCwtY 6n4RvbnpeMaiphtraU7rSfJZKsEVSQNcCNlxJu/oA0ilDFKcb5WvdmlfBunK2ZP2/BJJW06xR2Rl86YW9plRgV+0aic+CYyA5EIGuRbUqhUDFyZg1uA EXdg+VbO2ZUtVYSZRZae+ba4Fv80vYjuPhEV2LudNqdn+Wyy7V rT8aNiscIYI175DO7X7raRs6sH/AFMVRmv7E+2VtSXThglMQxsXfHjdyeLuRdjlx9EafdrbUuVVzG cGzyJa3GYDCbUEg87BhpeJhRSMC3qCmMS5fWMuSl+0DhvwJiGb 5bKmvMJo6Y3dbvjNlOZwvgGatkbG4PPSH8b8guot2Sjflesoiy G4DJMuMwVxDPwsb+iOI7zUk2zFVU4rizi4YWtdfnLwPCJts99u S5Jk9TJmIVw++KxNjcHRhGom7t7UObyJbfS++LQmlBwYknmUkc/rEMvqWVz5vasSLFGIzHC4tH0ruNtDr6GQ5JYhcDEm5JQlbk8zY H0xyObuxXnJqWWw8P5HURI93qvadHK6qVRSsNyxxNMJubDnlkB l3Rm48Gue+5L9v7VqJU9RJmUpTAWaVOfqmuCBnMubXxAgYR5pz zy3GxNqLUyhMUWzKsAwYBlyIDKbMO8Ry3aVFUVVR11XQIt1wTG kk4yADgNmuCyki14mG69PXU0gSyquoJKdZk4U52fCbXBv6LRGV kOSRMooTGmFVWfJS/WfvjUT5NYJayiczftqWDaE5m/siypctFHVXkmeU3wdKgSZqK2Jwl0a1rkAWuO0M+6JnHLKuuWra TiFpmQBVSmJmNsR7yRE6FVV/Iyz/fP3RW0Zaxa+qLd0NJp+6ZuYoVHKI3tPeGZTIZk9ZMpB8J5lh4D LM9wiH1XTXTISApmfuK1vW1ohxaCmnt9jqgUcopgHIeqOYUXTV SOQCpQn49wPWFIiY0G99PNANyoOjecp8GW/ttBQb2DnFbm/VQNMorFuTOVxiRgwPFTceuLkVLiEIQAhCEAIQhAGLXVySlu58A NT4RAN5d5Js26qSkvkDmf3j9kdDqadZilXFx/vTlEL3g3VZQWldpdSPhD7487HxrSh2bem563wueHjP+TfyvsQR zGM0ZdRLsYxGWPnEfawaseCIoqEkAC5JAA5k5Ae2PcWpoJGRIP AjUHgY1ha6vsTUcsryb20+ZuZe4tTO86akodxF/XrFJPR6ZU2W3lbFlImqcR85HSw1+d7IiNZtfaEvzT1g5qc/VFnZW81W0+VjV/66Wpup80vdv5CPo6MaNuyx8Jip4xyfWv/ALb8Hd5WzqiUk8z54m3ktwwjIG5NtDpmOXhGVstkmSpDGQZhSW uFry2t2ADYl75jnGp2LvGatKm5HYkki2WoOvqjBlbjoJSVEmfN lOUWYxDX1AZsJGE31te8bTcklljf3OfDxhJvPLLxpf7Ejrax5A mNKpi7mxEvEqnCAbscOIWvlbU52EaV98JK28qlVBci+FkAl/3ELWI5E3PfEsoJAkyruTe2J2ZixyHM5kAZDwjT7zVby5PXPTie oz6tmGGX8UstjjOl9bHTnFaymlmjK3tc0w7pylklHNfzzW++hX Ze06OtkElJay8VgszAM1sbgA5Z/wAo1u3anZwndROk4Gex6wIglkHRyb2YZWuQdI9Um/VNKUJMp51NzXqcK34kKDfXujJqZFFWyHqVUMArAsEKMcOZBUgE G41yPI5xXNnjaEk5ef8Awvk6U3KpCSh5Wf8A7szfbOLN2iUZR2 UZNGU27VuGlsiRlfwzoj0za6yWErBNGGWXGEphwIMwM+FrWjeC WfjN7PujqtY866ZDH2TUUaVM954mIJMwqoFsLWOHhnbSOfbpUl WtLU1NNOMpJWHEF1crmc+Sq1++8dk3hoDNpZ8sFiWlOoBtYkqb DIX1jmm420Aux64mwAEwFRfJmlLhNySc9PEd8EW8jL3n3jNXsZ XNsfXLKm2GWJQWvbvsp9MaKklVdFRU1fLnvgMwr1OI4Al2Iut7 EMQ18vhCLGzaCY2wamZnYVKzB+6oRGP+I+oxv9vVandynzzPVo P3kY4v+0xJJ0XZzJPZahcw0pGUHMDFiII5GxIv3xod9Hqlmy+o xlGF3wGxNsYC3UXABcHvtF7d/YIKULO7q9NJQ4VICsWQhg4IzA7rRJauSWHZNmGa8r9/dqPTAozn9NtnaMpQuBplrks655nTmQOZg+8m0vkB9GKVPSE8p2 lzFCupKsCMwRFg9Jg7osmuCjTPTbz7S+RA9EWG3j2nr1fsjy3S Se6Meb0hk8bROaJGWRt939vV0yplJNSyFs8u4/bHSI5Tu7vh11XJQt5zW9hjqt4o/QvHTcrFmfqv73/i0XbxanHNf3vsMQSR+n3Uky8ExWmXUq4Bfs3uDpbmY974b3ydn oMV5k5/6qQh7bnn81ebH2xHekHf6RQhpNOqTakDS3Ylci9tTyUem0cfp9 osxerqWM2bNucTHMKOI8SLAaWHfFYwjHSKsaTqTnrJ3NrvJtBq pzPrnV2A7CXPUygdFVfhd5N78jEffeNACsuWSP2a4QPAf6Rq50 5pzBnu1zaXLvr3nu7/ALNcuRhVwjljnZggCottcyMRsL8LRa/BnbkHbMtuzMQr++oP+vsjL2Ntd6OZjkWMtjd5ZN5bj/xb5w08I2e7M+knP1E6WUNynaAZLjI3IFhpqR6Yuby7jmjc4Tik vna98N9LHl7Rax4Eym9yrs9GdR2BO8okrVULsAcmX4SsNUcaEj 1cYkWyt5bt1dQAjaBtFJ7/AIv8vCOO9Dm2WpNoGlc+9zxh7sYBMtvVdfSvKO37V2Qs4cm5xu qkZ6TXuc8oSpu9N+xtxCIrs3aD0p6qfcy9A2pX71/lEpRgQCDcHMEcoynBwZvTqqa0KwhCKGghCEAIQhAGg3g3WlVIL D3uZ8YDIn5w4+Oscz21sebTNhmrYcGGat4H7NY7XFmqpkmKUmK GU6hhcRwYn4fTq9y0f7uetgfi1XDdsu6PHHyIts7cmkeVLZle7 IrGznUgExdbcCj5TB/9hiTyZQRQq5BQFA7hkI9xusLRtrFfQ5n8QxN21Ul9WRH83tH+1 +n/AKR5PR7Sr2kMwMM1u4tcaXy5xJ3kYWMxcybXGWg4L38c+VvCzt mcRTTnRrESnZWGoIQkERPhqK/qiHj8S95v6nOOjzcquoFqln9XMM6TgTq5l7EYhdsSiw7Q0vG+2 zs6tVKZZE4AhUDySwtilgE4WtcglbcNe+I10HbxVNW9R5TPedh RSuMjK5N7WA5eyNyjK+1ZrqzESRiviJFlKCYM+ADPlzAiuIkko x5dt7E4OLbnPTtTequuLG/2RvAtWFQrgmiYBNlnUYQzXHMYkA7obQ3kky6sSZ2JMChgzABLt i7d78ALA8yYvzthSpU5qtQTMxYzmbBbYZllGpw3PHONPs7akus nTVn0wOBSjkgEiXiJQ4T2h32vwOUVcqkUotrM3p6/guoUZylOMXkS111TfHKTJDLUVMvFjRgwuFwpMQX0DXuW77EeiM Ko2eGkLLp1WWWUy2UEhQl2vnbg97eLc401DujLp6hZsid73hOB SMZUnLFivZlAva4Jvz4SaTNSWAqnTiTcnvJ4x00YzlrKNmceJn Th2wndfQ1jbFnEzrmWQ+LB2muhdcLWOHMEWy7hEjBjBavHOLTb SEdGSTOLqxRsy8c12t0fzxOm+RzkSnqGDTZT3FrHFYWBuLk201 tE1SuFzduOXCwyy7+Pri6awc4dJjrIxtk7EkpRilAvK6sy2B1O K+PF3kkxDdndGzpNRJtR1lHKmGakqxuWPBhoO+2ueQuYm0urCk jge0Pt9tj6Y9NXDnE9NkddJbmTKI61jlcKo9Ha+4eqMrF3xpJV aOsfwX/yjJWuEHSZCrI0+3twKSsmdbN6wPaxKPa9r65G54egRqT0R0PEz +600afRiZLWDnA1Y5xXpsuq6tuQsdEtCPhVH1o/DFH6JaLg9R3e+L+CJl5UI8PXWi3SZXxPqRzY3RtS006XOR55eW cQDOpF7cewDbOJkYwRXCBrRDptEOun5mcDGg6RJ7yqCbMlMUmL YK6+cuJgGseGUbHy8Rqd6k8qpnkBsBewDWvYg3FxyuIOnImNaB 86bRlYVY3vx7yScyTxim25mGUEHJV9l/5iMneKjmSC8qcpV115EXyZTxB5xp9oT+sQ8wA3qyP84xOq99Td S9lsovbI2QZ2sgF29ZwjLviQ0tJJWSaipUzg79TLlrlnY9YCxK sAVD9w7zaM6m2AdpbMDyLGciiagHFhdZkv97X1rzjRbL3kSQj0 dXKWpW97aOjywS4EzVcRBXCNOd7iI8ijdz1tN5PVdfIXq1mky8 L5e+AkMMWeLIWsTbO+V7QTeOa0mTInqcS9gE53TLDn6V9KCMfa 23RWYaOklCm6u6ypcu+KY+JjYuupOJlsRqb3JiX1u6EvZ1DJE0 hqkjrJnGxbQX8beIltDUfMhMxzLraWYuWGYpP91gY+mqOrDDKP lfaE0tUywoLFLGwzOZvp4Zx9F0VQym1wfZG9OOe5hVnksyRVdG k1bMI0UmoeibA92kk5HUr3ju7o3NLU3i7VyFmqVOhgnl7ZbBrN 3w3MiXMDAFSCDmCNDHqIfKnzKF7G7ySdOXevf3RKqSqWaodDiU/7seR7opUpuOvkaUqqnps+C9CEIzNhCIF+eDZXyz/UTPww/O/sr5aZ9RN/DE2YJ7CIH+d7Zfy7/UTfwRU9Luyvl3+om/ghZgncI51L6V9mgtaqfNrgeTTjbuFxF4dLOzf0lv4ab+GFmCdz JwWwJAxHCL8TYmw9AMazeE4KaoPwTKmX+aSjZ+B/n4xEarpQ2XMGFqlxYhgVp5oYMMwQcJjAbpOo5iVEubVDBMRpct hTzsQxKVxFcNrZ3tfnpfKjclK1v31LqKcb32/dDlXR1vwdlma4lCb1iqpu1rWJPp1iV03TJLluXTZ8pWYYWKta4 1NwBaIf7ndnAW/Kv/QTuHpinua2d+tf+gn/AHxZxvuiqk1ez39SfUHTfMsFFIGwiwvMN7cL5Z2FhfjaNfK6SG l1IqEpSpwFCofJl+CDlwGED90RGJG7tACCu1Rf/wCDP++LW2ZUqUAZNWtRzAp5ssj0OLEen0QlBStdbExnKF7PfT2 Ju/Sxc3NK9ybk4xmefmxbPSn/AOlmfTH3RzF65u/6H+sbTYlOk65nVkqmtoJkmY5PoRSAPE+iNlUkjB0IN3sTad0sI vnU0wf3x90WW6WUAv5LMt/7g/DEbn7s0bm7bXkH/wDNP/DBN2aMC35WpiO+nn/hh1p8keHhwSH87sv9GmfWD8MXk6YZY/5aZ9YPwxE/clRfram/h5/4YDdOj/W1P/Dz/wAEOtUHh4cEqm9MUs2Pk0wW/aD8MXF6WkYX8lmfWD7oiB3So/1tT/UT/wAEXpG7NIum1qY+Mif+GHWmPDU+CVJ0pIGJ8mm5gZB14X+b3xd fpalrmaabb98fdEVGwaX9a0n1U/8ABFH3fpCLHatKQf2E/wDDE9aY8NT4JQOmWT+jzfpj7ovp0uoRcUs08R21+6IKd06Ma7W p/wCHqPwRlUm79IgsNq05HfTVH4IjrTHhqfBL/wA7qFreSzQdbY109UWZnTDJvnTzfpj7oi87YNIzA/lWnuOVNUeo9mMeo3Wo2N/yrIvxtTVH4IdafJHhqfBL/wA8Um/9RN+mv3QPTFJ/R5n01+6IUd1aP9ayP4ao/wAuPB3Xo/1pJ/hqn/Lh1p8jw1PgnK9MEj5CYP7w+6M3ZHSOtXNWVJppjucTBA4BYIpd gLjWymw4xzc7tUf60lfwtT/lxv8AcOXQ0FdJqX2gjrLxXVaapBOJGXK8u2pEOtU5HhqfBd3s3 5pq+WU8lmh18yZjBZTyIwi6niPtiM7J3YqZ9POq5KhlpyBMTPG VYEllW3aUDXO9oku+tPsyprGqaOtWQJgxTEelqCOsN8TLhl5Bs iRzueMSfoy3q2fsyVOSdWCYZjhwZdNUAABbWOKXGcpN6s1jBRV kQLcbeCZSOWkklCblb5qdD7MuRAHEAjO3nrjVTxPElMYIOIdkk jS9tfA38Y2G+0rYtQ7T6Gqelnm7FfJ53VM2ugS8u/G1x3RBhtacpI7MwDLFYi/fwPrAiCHHW6Ol7nbZpdnoXSnTygj+sbtML62NyT4XWI5vbvY05 i803JzC31PPw09AsIizbTnObdiUD8Igm3fxPqET/cc7Eo3E+qqJlVUAhhemmiWjDQqpW7Ecz6AIBRfmb7o66Klm0/lNf1qzppxoiuUKIRljy1N724C0T5tkzy9ykqXi4deWztnYdUL8 4io6RNmJNedLqnV3a/apZjgCwFgLAg3BORGuYjITpT2apDmfMmvfCWanmDChPaEsBbLz 4k210itOpUi9Fb8GlWhSktXf8ml3k6TFoKmbTNKZ2lEKSrZG6q 2Vx3xrz05gaU7H++B9kRvfKTs6urJ1SNomWJrBsBopxIsqrmcr 6Rozu9QfrM/wM7741dST3+xgqEFt9yfTemgTBZqRiD+0H4YmfRZtZq0PPlKZM tZhlTEdsRYhAwIGEAZsM+4844lK2LQrptI/wM38UdX6GNs0cjFRS6hp82dNaap8neWoAlrcHFfOyExDnO1vIl UYqWbzOuQhCKGp8prus19Dryi9L3Xb4p9Ud/bdtb6RQ7voBpFsxJwcbrn4pg+6bW80iO8pu+ttIuDYCjhDMD58 lbqtitaL/uTPxTHdF2AobSMn8hJ8WGYg4H7lDbQxZm7sEcDHfJm7q8BGLO3 cBv2YZgcG/IB74q27xHOO4Jupn5sXG3R+aInMDhcvYR749vsNu+O3+5ID4Me pW63Arb0QzA4W2wW5GPB3fblHexumOQij7pjkPVDMDgnuebvjy dgmO/rumLZiMWbumB8EerOIzA4gm71+cX13ZOljHbKTdYfFjMG64OoE MwODHddhwPqjz7mm5H1R3mbuzyAtFxN1hxAhmBwBd2TyMe/c2eR9Ud4XdURel7rreGYHAxu6fin1RdTdttcJ9Ud6fdhOAj0u7 KW0EMwOBpu8eUH3eI1BEd6G7KjgPVFudusphmBwaZsAjhFkbvM dAY7xM3TU8IvSN1kHAQzA4CN225GPZ3WYcD6o+gBuwnIRdbd1L eaIZgfOx3fbvjwdgkagx9BtuonL2Rjzd0U5QzEnz+diGKjYRGt 47tN3NT4oivuQXkIZgcJbYpi0+xjfjHcn3OHxR6oxZ25eeQyhm RBxcbGMU/Ijd8dvp9yhyEZSblryhmQOCNsRuUVGxW5R333Fp8UR7Tc1bHIe qGYHAPyO0S/ok2aybTkMeAf2y2EdPG5KHVR6o2mxd2Up5gmKACL8OYtDMCRQh CKgR5KiEIAraKwhAFMMVhCAKEQtCEAVhCEAIQhACEIQAhCEAIQ hACEIQAhCEAIQhACEIQAhCEAIQhACEIQAiloQgBhihUQhAFcMV tCEAIQhACEIQAEIQgD/2Q== |
Trash all that after the indy car jpeg! Yikes
We have 18 wheelers everywhere! The California coast riders with Craig Vetter in Monterey get strong winds off the ocean. I get the thunderstorm winds especially crossing the river here. My bicycle fairings have done well because I attach to the head tube rather than the handlebars as do most fairings available. Since a motorcycle has 4 to 4.5 inches of ground clearance, floating plastic skirts could be made. The Chaparral 2J used them to get a partial vacuum under the car for down force. A gas fan would use fuel too.
Thanks Grant . I'll have to investigate skirts .
A brainstorm (or brain fart) might be to use a pyramid shape as the fuselage of the F-117 aircraft. Being wide at the base and pivoting at the top like a bell and clapper, the motorcycle could tilt inside while the shell is suctioned to the ground with a couple of gas leaf blowers. Good for smooth roads only.
:D Now that is getting way too complicated and I hate leaf blowers !
But the F117 is along the lines of my original brain bubble . Those flat sides and rapid intersections don't look aerodynamic but it works. |
The issue also arises of engine (and rider) cooling and how much power would be needed to run an electric fan. The tapered side would give some Newtonian down force. The flat sides might be easier to fabricate but I wouldn't count on being invisible to police radar.
Much of this has been discussed in other threads going back a few years.
. http://ecomodder.com/forum/440784-post225.html . My new tail is a complete non issue with regard to cross winds. Even the full streamliners are minimally disturbed by cross winds as long as there is an open vent for the pressure differential at the point of max thickness/ lift. . . https://scontent-ord1-1.xx.fbcdn.net...b2&oe=5652D512 . . |
I've been thinking along the lines of sliding "doors" that could be slid back inside the rear to cover those openings in the interests of reduced drag. That would seem to require the flat sides.
Actually the doors could be flat or concentric. The larger cross section would be in front so the door would slide on the outside as in the minivan application.
A straight sided fairing leaves a huge wake since it is not streamlined. But at least the rider can gain some weather protection and some useful locking storage.
I think I need to bandsaw out a shape, take a photo and post it to give you an idea of what I have in mind.....
Here are few photos of a rough model I made today. The sides are flat and the maximum cross section is around mid way but there is no foil. The rear could be narrowed more or even tapered a little without generating lift.
It is quite similar to the Vetter fairing and would have the same frontal area . Could i have some comments on this idea ? http://i1062.photobucket.com/albums/...P7230533_1.jpg http://i1062.photobucket.com/albums/...d/P7230537.jpg http://i1062.photobucket.com/albums/...d/P7230538.jpg |
Honestly, it would be much more aerodynamic if you tapered the sides. You punch a hole through the air and if your vehicle taper, you leave a smaller hole, creating less drag. The back of my Civic tapers a few inches behind the rear wheels. This is pretty standard. The Gen1 Insight tapers more than most cars and it is very aerodynamic.
I see now that you mean to taper the sides so they are narrower in the back. By "straight sided" I had assumed that you meant parallel. The Vetter tails are tapered at 16 degrees and flat sided just like your truncated tail that you are showing.
Thus some increase in drag is likely but far less side lift. The side lift is something that worries me a great deal, the winds were i ride are extremely variable and if i ride on main roads or freeways the are a large number of very large trucks of the huge moving van variety. Side lift could easily toss me into the path of another vehicle. As little side lift as possible is preferable, even at the cost of drag.. |
comment
*you must reduce or eliminate separation to do this. *historically,gentle,progessive plan taper is the only way to accomplish this. *and this requires a curvilinear pathway. *a straight curve has too much pressure gain to respect a turbulent boundary layer's needs to mitigate counterflow,eddy initiation,then full-blown turbulence. *to complicate things,the body upstream of the taper is mutilated due to the cavity for the rider,so the onset flow to the tail is adulterated already. *boat-tailing requires clean,turbulence-free flow to perform properly. -------------------------------------------------------------------------- *Since your fairing is a crude,upright wing section it cannot tolerate a Kamm truncation.Chopping it off creates an exponential drag increase. *for drag reduction the tail needs to be curved to a point,even if it's not to an ideal length. -------------------------------------------------------------------------- *if you're concerned about crosswind and gust dynamics,it's my opinion that you need to ride with extreme vigilance,and use the body cavity to lean out,using body English to address your immediate riding environment. here is the minimum drag section (center) http://i1271.photobucket.com/albums/...rohead2/-2.jpg Here you can see how drag is compromised as you leave the ideal contour http://i1271.photobucket.com/albums/...head2/8-24.jpg Here is the numerical relationship with which you can predict your drag penalty for truncating the tail http://i1271.photobucket.com/albums/...2/8-16-132.jpg Here are some examples of proper streamlining http://i1271.photobucket.com/albums/...2/HPIM2007.jpg http://i1271.photobucket.com/albums/...2/HPIM1997.jpg http://i1271.photobucket.com/albums/...2/HPIM2002.jpg http://i1271.photobucket.com/albums/...2/HPIM1979.jpg http://i1271.photobucket.com/albums/...2/HPIM1954.jpg http://i1271.photobucket.com/albums/...2/HPIM1920.jpg |
''*a straight curve has too much pressure gain to respect a turbulent boundary layer's needs to mitigate counterflow,eddy initiation,then full-blown turbulence.'' Could you explain that in other words ? I'm finding your meaning a little hard to derive . I've modified my rough model , improving the nose area shape and smoothing it more back to the rider's position, the rear remains flat but tapered. My understanding of this is that it is the angle at which the body leaves the air that is most important. I appreciate that my design will generate some flow separation forward .... but then that is the whole point if the side lift is to be avoided and that seems the primary gain, it could keep me alive. |
Basically what he is saying is that your design won't be very low in drag.
I guess I'll have to build it and see .
Tuft test, if you can.
But you will gain some nice storage capacity and weather protection so even if it is only a slight improvement in drag, it is still nice to have a fairing and trucated tail. My tail and a new chain have given me an extra 10% in fuel economy to now average 102 mpgUS and now I can go shopping for more items or lock up my stuff when I am gone camping.
. . https://scontent-lga1-1.xx.fbcdn.net...b2&oe=5652D512 . . |
I hope for a fair bit more than 10% !
I guess I'll see. |
Sendler, I'm a little disappointed your well made tail is only improving your mpg by 10%. From my studying on the subject I would have guessed around 20% improvement.
The utility aspect is surely a nice gain though. I need to build a tailbox. Though I have been hesitant since I carry my mountain bike on my rear rack once a week. I'd have to make the tailbox quickly removable. |
