Strange behavior when editing parms[]
I want to delete some unused parameters in parms[] array. I edited the parmLabels[] and #define Name number also, of course. But when the code is uploaded, it doesn't work like expected: Display is very bright and its very hard to read something. Also middle button don't change anything.
I searched the code up and down, but found no error. Any hints? .) The number of elements in the array is defined with sizeof -> should work .) #define contrastIdx 0 etc is OK .) Labels also changed. .) What I forgot to do? Edit: I can't find the delete button.. (feel free to delete) Found it: Of course it loads the old, bigger array on startup. Disable load in setup, run into setup menue and save. Now it works fine again :rolleyes: |
