Streamlining the Civic (2005 Civic EX coupe)
I've been doing some work since joining this forum a couple months ago and perusing the information here. I've gone from consistent 37-38mpg tanks to a best of 51.7mpg and 90-day average of 47mpg! Most of my driving is on the highway, with a 45-mile (one-way) commute three days a week through pancake-flat central Illinois, so I've been focusing on aerodynamic modifications for the open road and gliding and coasting around town. I figured I'd start a build thread here to chronicle the mods and my results.
First up: lowering. I've had height-adjustable coilovers on the Civic since last year, so I lowered the ride height a bit more to get rid of as much wheelwell gap as possible: http://i1047.photobucket.com/albums/...315_113102.jpg Next up were the mirrors. I was surprised how much removing the side mirrors changed the look of the car. Before: http://i1047.photobucket.com/albums/...129_153025.jpg (I ditched the front plate, too). The mirrors were replaced with convex mirrors from Autozone. I didn't trust the 3M tape to hold them to the sail panels, so I used some screws to mechanically attach them: http://i1047.photobucket.com/albums/...316_163039.jpg http://i1047.photobucket.com/albums/...316_163020.jpg The driver side mirror started sagging after a few days, so I epoxied the ball joint at the base of each mirror. On the outside, I cut a closeout panel out of some flashing and reused the rubber moisture barrier from the mirrors and three bolts through the stock mounting holes, with silicon caulk to seal the edge gaps. http://i1047.photobucket.com/albums/...419_150223.jpg When I bought the car a couple of years ago, it was riding on the original tires. I was planning on replacing them this spring anyway, so I picked up some LRR Continentals on cheap steel wheels and a set of solid wheel covers. http://i1047.photobucket.com/albums/...419_150256.jpg Finally, to finish the front end, grill blocks were in order. After driving around with a temporary (cardboard and duct tape!) full upper grill block and partial (2/3 covered) lower grill block, I decided to use sheet metal to smooth over the whole front and cover the fog light indentations as well. http://i1047.photobucket.com/albums/...419_150232.jpg The radiator inlet is now significantly smaller, so I've been keeping a close eye on coolant temperature. It seems fine for now, but if I need to enlarge it when 90-degree temperatures roll around, it should be pretty easy to do with a pair of snips. http://i1047.photobucket.com/albums/...419_150201.jpg As it sits now: http://i1047.photobucket.com/albums/...419_150150.jpg Next up, I'll turn my attention to the underside and rear end. My goal for the near future is an 845-mile trip to New Jersey this summer for my brother's wedding: I'd like to do it on one tank (13.2 gallons) or as close to that as possible, which will require the car to get ~65mpg. I'm not sure if that will be possible, but, hey--dream big, right? |
Looking good! Love those mods.
How much adjustibility do you have with your coil overs, what brand ect. |
Thanks! I got the coilovers from AMR Engineering in Seattle; they're a great value for the price (Hypercoil springs, etc.), custom built with user-specified spring rates and valving, and were highly recommended by lots of people on Honda Tech.
64 mpg
s place. I think you'd need at least a couple feet of boat tail behind you to have a fighting chance.Your existing wake is just too big and powerful.You've got to shed some of that load. |
Looking very much like this one here : http://image.turbomagazine.com/f/900...front_view.jpg
Very nice work. Any plans for wheel skirts?
further
*@ 60%,Cd 0.153 (think EV-1 with its tailcone at 183 mph at Ft.Stockton,Tx) *@ 70%,Cd 0.140 *@ 80%,Cd 0.133 After 80% you're pretty much in 'phantom' tail territory and additional length couldn't get you below Cd 0.13 unless you went after the wheels/tires. If you attacked those,then might be looking at Cd 0.11 or so. My truck is at Cd 0.18 at its present length with the quirky rear bed corners. basjoos is at Cd 0.17 with AeroCivic. -------------------------------------------------------------------------- If you execute a tail mod staying close to the 'template',you could start at 50% and then later, if you got hungry for more savings,you could just extend it some more.'Plug-and play.';) |
very clean.
I would go w/ black. The red w/ dark tint is just beggin for black!! |
Looks very much like the Bonneville race car. Also, the aluminum sets off the wheels quote well. The car looks great, though I would install a shelf spoiler to the car. ( which is just what was on that Bonneville car ! ) |
One thing I would black out would be the area where the mirror was.
I think it draws too much attention from the police. |
looks good!
Awesome. I'm the opposite- they're legal where registered in MN but at college in MI they're illegal. I've been pulled over in both states and neither mentioned the mirrors (though one was at night).
It looks like you have some non-eco mods on the car, too (coils, grille, head and tail lights) so I'm wondering if you race it or if it's just for street fun. My Rabbit's got coils and I definitely didn't buy them for fuel economy! ;) |
Yup--I've had fun autocrossing the car. Now I work weekends, though, and since its primary function is as a commuter I've decided to take it in a different (and more economical) direction.
I've been reading all the boattail threads I can find on here, and the idea is really growing on me (especially with those potential Cd values Aerohead posted!). I'm thinking of a 36"-38" extension past the rear bumper (~60% of template), moving the license plate and stock taillight housings to the end of the taper, and building the tail out of foam blocks and fiberglass (using 3-wheeler's method). I have to be able to see out the rear to have a legal mirror situation, so I'm thinking of using a piece of Lexan doubling as a hatch for trunk access, and removing the trunklid since it would be superfluous. This would also allow me to use the trunk edges as mounting points, in addition to a support on the bumper and perhaps in the taillight holes. |
rearview mirror
If you have any clear plastic laying around you might prop it against the back of the car at the anticipated angle and look through the rearview to check your rearward vision. Should it be a problem,you can always do a small,vertical, 'step' backlight which is inset into the rear slope.It doesn't have to be very large and the recessed area around it will simply capture a vortex of which the outer flow will just skip over.Many supercars and competition race cars have used this when running proper K-Form rooflines. |
Subscribed. I like that red body + sheet aluminum / stainless look.
impact
*I extended the C-pillars along the 'template' curvature on each side of the hatch. *At the top,I had a cantilever wing projecting out about a foot along the 'T' curve. *Then I had a low wing which extended back to intercept the 'T' curve which morphed into the boat tail. Leaves captured inside the 'void' would dance around,impelled by the vortex,with outer flow glancing off the vortex. |
Before I embark on the tail, I figured it would be good to get some more fiberglass experience since I have very little (I built a sub box once, but that's about it). So, I found some inspiration in this thread and started chopping up my stock mirrors. I basically followed the same process, with the exception of having to glass in the plastic bit that holds the attachment bolts as it's a separate piece from the mirror housing in my car. Bondoed and sanded:
http://i1047.photobucket.com/albums/...507_193142.jpg Painted and on the car: http://i1047.photobucket.com/albums/...508_161307.jpg http://i1047.photobucket.com/albums/...508_161255.jpg Next up, I'm going to glass and paint the upper grill to match, and then do the lower bumper. Then I think I'll be ready to tackle a full tail. |
any further progress?
And done! After removing the flashing, I filled the grill and lower fascia opening with expanding foam:
http://i1047.photobucket.com/albums/...528_093954.jpg http://i1047.photobucket.com/albums/...528_093945.jpg Cut off the excess with a kitchen knife: http://i1047.photobucket.com/albums/...528_102855.jpg http://i1047.photobucket.com/albums/...528_105417.jpg Then fiberglassed: http://i1047.photobucket.com/albums/...528_171909.jpg After our hottest weekend of the year last week (97--and it's only in the 50s today), I noticed my temperature creeping up when the AC was running. So I made the radiator inlet slightly larger than what I had in the sheet metal: http://i1047.photobucket.com/albums/...528_172016.jpg Sanding: http://i1047.photobucket.com/albums/...529_112251.jpg Lots of sanding: http://i1047.photobucket.com/albums/...529_140350.jpg Painted: http://i1047.photobucket.com/albums/...531_214151.jpg And on the car! http://i1047.photobucket.com/albums/...601_141336.jpg I adhered to the 10-foot rule; it looks pretty good...from 10 feet away. If I have more time in the future I can go back and clean up some spots, but overall I'm happy with it for how much time I put in. And it looks much less conspicuous than the galvanized steel! |
Dang Dog..Really great work!! Great pics too. Thanks a bunch for sharing.
Excellent.
Fantastic job. But why black? Why not make it red like the rest of the body? Just wondering, looks really good.
I can answer that..... you never get a perfect match when you try to go factory color.
The black is PERFECT!!!!!! |
Nice job Vman. How do you see out your side mirrors. Seems like there may be some safety issues. When I had an Illinois drivers license I was required to have outside mirrors. It is a fairly common restriction.
Do you have narrow mirrors in your flattish panels? |
I went with black for a few reasons--black was readily available, whereas factory matching color would have had to be ordered, and I thought it might look weird with the negative space of the stock grill and foglight hole covers turned red. I wasn't planning on extending the black that far out the sides, but I got carried away sanding.:p Plus, the black will match my eventual tail.
Very nice work! Thank you for sharing :)
Looks good, did you do anything to the bumper to get the glass to adhere better? I almost did this back in 09, but the civic that did the foam/fiberglass bumper back then, he had problems with it cracking off of the bumper. The polyester resin doesnt stick to plastic very well. In the audio world, a lot of times, we'll drill a bunch of small holes through the plastic to get it to adhere better.
You should be fine then, its rare people at home use epoxy resin. Not only should it adhere better, but its a little more flexible, so it should give a little more before breaking, in case anything hits it.
Well, I haven't had time to build my tail, and I'm leaving Wednesday for New Jersey. I did get coroplast full pans on the front and rear of the car (with aluminum under the downpipe and catalytic converter in front after the plastic started melting!) and a couple panels in the middle to cover up the center tunnel. I'm also experimenting with 6 vortex generators on the rear window, after tuft testing without them, with 10, and then removing 4--they're keeping the flow attached now, but if they're having an effect on fuel economy, it's not significant enough to tell. I may try and fab up a temporary coroplast-and-tape box cavity tomorrow if I have time....
Looks slick, have a good trip!
I'm considering it on my '01 Civic, but not sure if it's worth the hassle. |
Copyright ©2000 - 2021, vBulletin Solutions Inc.
