Stricter EPA testing for 2017 model year - be careful making comparisons
1 Attachment(s)
http://ecomodder.com/forum/attachmen...1&d=1466104392
The EPA has introduced stricter fuel economy testing methods, starting with the 2017 model year. The changes apply to coastdown testing to determine a vehicle's aerodynamic and mechanical resistance -- values which are then fed into the chassis dynamometers used during the actual laboratory fuel economy & emissions tests. Remember how a few automakers got in trouble in the past few years for using "erroneous" (haha) road load values which under-reported aero/mechanical drag and therefore inflated their fuel economy ratings vs. real world results? Hyundai, for example. The same thing has been going on recently in Japan with Suzuki and Mitsubishi both getting in crap for gaming road load values for their government's tests. The takeaway: Keep these changes in mind when comparing the EPA ratings of 2017 vehicles to previous years. They're not 100% apples-to-apples. Even a vehicle that carries over basically unchanged between 2016 and 2017 will likely have a lower MPG rating, as these examples show:
Not surprisingly, most of the changes affect the highway rating (except for, interestingly, the Ford Fusion hybrid). However, the differences -- 1 MPG US in each case -- are small enough they may not change the vehicle's overall or "combined" rating (except for the Camry, which drops by 1 MPG). But in the cut-throat world of marketing, where 1 MPG may make the difference between being able to trumpet "best in class" or not, keep your skeptical eyes open. More info:
I wonder if the Elio will still get 84 highway? Do they have the testing standards out for 2023 yet?
Green Car Reports has picked up this story:
Gas mileage ratings for some 2017 cars to fall as EPA tweaks tests |
Yes, wouldn't it be interesting to know just how many they've audited and discovered "discrepancies"?
Of the relatively small number of 2017 models available on fueleconomy.gov to compare with equivalent 2016's, almost all seem to have dropped. |
The first time I noticed this was when looking at the Ford Flex and Lincoln MKT "twins". Both had the same aerodynamic factor and therefore the same EPA ratings. I just had a hard time believing these have identical drag.
http://wildsau.ca/wp-content/uploads...e1-640x640.jpg |
It's amusing that with the leeway they get via legal loopholes, some manufacturers still went the extra mile in gaming the tests illegally.
- Despite the fact that they keep finding and closing these loopholes, I still hold that the EPA tests are as close as we can get to a realistic economy test among the major markets... and this development simply makes it even better. |
No, you're right. I was looking at the lack of hope of their seeing production, you're looking at the problems it's causing that market.
The white one has an aero spoiler and the roof slopes down as it goes back. The bottom also slopes up at the back. Flex is just a brick.
They were both on my list of potential buys but after seeing supposedly the strange looks of the Lincoln gave no benifits I figured you might as well take the extra room of the Ford. I think Ford just didn't want to show an advantage in one over the other, or the EPA let's them save money not even having to test each model and let's them just call it a "twin". Like a GMC Sierra vs a Chevy Silverado or an actual twin like a Dodge Neon compared to a Plymouth Neon.
Most European 'brick' shaped vans are now managing 0.31cd's so perhaps the brick has been getting a undeserved bad rap all these years. Jaguar E Type and Jeep Wrangler share the same cd. |
