Stupid driving stunt (1000 miles on 1 tank - 2010 Prius)
Hi,
Recently, I wasted 45.5 hours between July 3 and July 21 to burn 10.9 gallons: http://hiwaay.net/~bzwilson/prius/1000mi_721a.jpg Wasted because I knew the car could easily achieve 1,000 miles on a single tank. But thanks to our Japanese Prius friends, I figured out how to do it while commuting to work and the ordinary chores around town. The full write-up is over a PriusChat but the technical details:
The trick our Japanese friends taught was to break a marathon into smaller bites. So instead of my typical one hour driving each day, I averaged three hours per day including the weekends. I simply incorporated the additional driving needed to reach 1,000 miles on one tank of gas. Marathon driving is not about getting somewhere, it is about putting the maximum number of miles on one tank even if it means 'doing laps.' BTW, I know this is accurate as I use both GPS and mile markers to verify the odometer and trip meter distances are accurate to less than 1%. So too is the indicated 91.8 MPG. It turns out the original tires are ~5% too small and that screws up the indicated mph, MPG, and miles. My replacement, Sumitomo T4s are right on the numbers as are the mph, MPG, and miles. I'm hoping more Prius owners will replicate this approach so doing 1,000 miles in a Prius is common and for us unexceptional. Personally, it is one long boring slog relieved only by having iPad music and podcasts. I've tried to cover all of the technical details in the PriusChat thread but if there are any questions, feel free to ask. Bob Wilson ps. I don't think there is much operator skill as much as the excellent engineering that went into the Prius. I mostly just kept it on the road and paid for the gas . . . enough for 11 cuppa coffee from Starbucks. |
I've thought about doing the same thing with my daily commute route, just knocking a bit off one end. I know I don't have a hybrid(yet), but still might get some cool numbers.
During the stunt, I had a lot of time to stare at the Scangauge II fuel consumption:
Still, you are welcome to the effort. I found it a long and boring waste of time. I already knew I could achieve any indicated MPG over any arbitrary distance. Going a 1,000 miles was just validation. GOOD LUCK! Bob Wilson |
I am curious about your warm up. Even though you can achieve higher mpg, what is your fuel consumption? Isn't it better to optimize your route for lowest fuel consumption rather than mileage?
Understood, Bob. I'd be doing it for the same reason, more or less. Basically, to see what the car and I were capable in nearly ideal conditions. Kind of like being in a rally all alone:D. It would also give a target to shoot for on my bi-weekly fill up.
Bob Wilson |
I could beat that with almost no effort. Just jack up the front end, put it in drive, and walk away. After all, it seems your purpose was just to see how high a number you could get on the FE indicator. Sure, the car isn't actually going anywhere, but if you were driving with no purpose, what's the difference? A car like the Prius was built for the purpose of efficiency, be it for economic or ecological. What you did was neither. More power to you, if for nothing else than for your patience. It is an interesting intellectual exercise. Now do some mods and see if you can test the results doing so (although for the sake of your sanity I might recommend using a smaller amount of fuel than a full tank).
Edit: that was a lot harsher than I meant it to be. I just meant to encourage you to take it a step further. |
http://hiwaay.net/~bzwilson/prius/pri_2010_800.jpg I knew before starting the marathon that I would achieve a 1,000 mile tank and it is no accident that I parked it Sunday afternoon, July 21 with this on the display: http://hiwaay.net/~bzwilson/prius/1000mi_721a.jpg I actually calculated on the 'loop' when to drive to my work and park the car. My goal was 1,000 miles. When I've read about the days and man-hours wasted in marathon drives, I would shake my head and mutter to myself that it only takes 10 miles to map car performance. But earlier this year, I realized I could incorporate the marathon hours into my normal work commute . . . do it in small bites. Instead of doing a multi-day, dedicated, drive (plenty of examples exist,) I added extra time to my regular 15-20 minutes per trips . . . extended to an hour. I spent the extra 40-45 minutes listening to podcasts or music. Still mostly a waste of time but tolerable. Quote:
My normal Prius is a 2003 model. Adding a couple of microcontrollers networked together:
A lawyer would take one look at it and after laughing hysterically say not just no but "H*LL NO!" But is this approach any worse than Google's self-driving cars? Well Toyota has been sued for 'runaway acceleration' and I have no interest in wasting time in court. Like this marathon driving stunt, I know it can be done but that does not mean it is worth my time. Bob Wilson |
