Old 03-10-2008, 05:44 PM   #1 (permalink)
HotRod's Avatar
HotRod - '94 Geo Metro Reg
90 day: 58.89 mpg (US)
Geo Metro Kill Switch Idea?
I am trying to rack my brain of a less anoying way to kill the engine for EOC. Currently it's set up like this. Turn key to off "BEEP!>>>BEEP!>>>BEEP!"; after 5 seconds, turn to run "BEEEEEEEEEEEEEEEEEEEEEP"!
AAAAHHHHH!
It's freakin loud and terribly anoying.
So, (sigh) this is what I was thinking...
1. going to the engine fuse
2. remove fuse and run a set of wires, one on each side of the empty socket
3. run wires to a simple switch located where ever is most conveniant.
4. run an inline fuse (to replace the old one) so as not to expose the circuit.
5. Simply hit the toggle switch for a couple seconds and then flip is back.
What I am worried about is whether that would be hard on the engine/computer to use this method. What am i not thinking of?
I am not a Hippie...I am cheap.
Old 03-10-2008, 07:01 PM   #2 (permalink)
HotRod's Avatar
Crap, should have search the forum before I posted.
I see AndrewJ already did this...right when I thought that i thought a thought...
Old 03-11-2008, 01:05 AM   #3 (permalink)
I"m not lurking!
s2man's Avatar
Porthos - '96 Chevrolet Cavalier
90 day: 31.3 mpg (US)
I thought he did...
Roll on,
Stew
Old 03-11-2008, 12:27 PM   #4 (permalink)
jwxr7's Avatar
the metro experience (retired) - '94 geo metro 4 dr HB
90 day: 66.44 mpg (US)
I put a normally closed momentary push button in series with my fuel injector to kill my engine. It works very well and the computer doesn't seem to mind. I like it better than just cutting off spark because no unused fuel is wasted . It bump starts instantly too.
Best tank= 81.23 mpg on 07-01-2008
Longest range= 791 miles on 9.74 gallons
Old 07-28-2008, 11:43 AM   #5 (permalink)
SirKeats's Avatar
GeRide - '89 Geo Metro *XFi
90 day: 54.26 mpg (US)
i'm having trouble finding andrew's thread on this. looking for a how too so i can run a switch myself. can someone point me in the right direction?
thanks!
Old 01-27-2011, 06:13 PM   #6 (permalink)
49state 4door - '91 Geo Metro 4 door
90 day: 59.31 mpg (US)
old blue - '91 Geo Metro base CA
I'm off to pick u part to get a FI resistor and its connector. Mine measures 2 ohms, but I want to make an adapter cable to bring the kill switch and both sides of the resistor into the cab. That way you aren't bypassing a fuse, cutting into wires or any of that. If a setup doesn't work, unplug the adapter and you are back to stock. Stock is important for California smog tests.
Kill switch for 88-95 Honda Civic/CRX/DelSol AndrewJ DIY / How-to 40 06-18-2012 03:13 AM
Selling an Insight - looking for advice on buying a Geo Metro budomove Off-Topic Tech 26 05-19-2009 10:14 PM
1993 Geo Metro brake rotors won't come off LibbyMetro Off-Topic Tech 19 03-02-2009 07:46 PM
Winter mod - heater blower integrated with engine kill switch MetroMPG EcoModding Central 3 12-31-2007 10:31 PM
Video: Geo Metro Commercial! Peakster General Efficiency Discussion 5 12-13-2007 09:54 PM
