Thanks -- best explanation of vena contracta I've seen.
No-no! Thou may not utter the phrase 'vena contracta' and 'understanding' in the same sentence!
That goes against the ecomodder law which states: Only aerohead may utter 'vena contracta', with the utter conviction of knowing that only he will ever 'know' and NOT to even try explain it to mere mortals, thereby dethroning himself!
The high fractional Mach number extends further down the throat.
It does more than that:
The number is higher, by 30%.
Air weighs ~1.225 kilograms per cubic meter (at sea level and 15°C; 59°F).
So you get a BIG increase in air kinetic energy (1/2 * m
v²), that can be captured in the chamber as increased pressure, with clever valve timing.
(square 30%...)
Also NB the thickness of the slow to dead air on the the tract's surface.
That means you have 'lost' what? ~20% of your intake tract diameter in the pic..?
So if it's say 40mm; pipe area is
1257 mm².
Minus 20% = 32mm; pipe area is
down to 804mm²..!
It's 'just weird' that many people are all 'aero the outside of the car!'
but 'too hell with (even thinking about) the inside'...
