Suzuki DR200SE
I have just purchased a 2001 Suzuki DR200SE. Suzuki actually advertises this bike as being capable of 105mpg fuel economy. (your mileage may vary!)
After it stops raining, I am excited to get on the road and make some base line measurements to see what this machine can really do. It looks like a great prospect to actually record a triple digit mpg number.:) There is some deferred maintenance to get done first so as to bring everything up to spec. I am compiling a list of mods which I would like to try as well. If anyone has experience with this bike. Please let me know what you have already learned. Thanks! RM |
great bike to start with! The 105 seems optimistic as stock, but there's alot of cheap and easy mods to that bike to make it more streetable and eco.
I was looking at that bike for ecomodding. Im interested in seen what you can do with it. Good luck.
gil |
good bike. i would say it will probably get between 85-90 with easy driving. 105 is pretty high, but you can hope.
Whoohoo! Have fun and good luck with it, GoSlow. Is it your first motorcycle?
Does it go fast enough to use on the interstate?
Here is an update on the DR200SE project. It has been almost constant rain since I brought it home, so I have not done much. I have made a few local rides to get acquainted with it's "personality".
It has good torque from right off idle and a smooth power delivery at low rpms. My technique for hypermiling is to shift up through the gears quickly keeping the rpms to a minimum. This motor seems well suited to this task suggesting very mild cam timing. I found some (unverified) cam specs online which would verify this. Here- stock DR200 cam _________lobe lift______valve lift____Duration at .050" Intake____.245"________.320"_______204 Exhaust___.230"________.290"______ 200 I also ran a compression test and was surprised to record a 185 psi reading. I repeated the test two more times with the same results. My gauge is the kind that you press in to the spark plug hole as opposed to screw in. You could feel a good strong pressure which makes me think that these readings are accurate. I am very pleased about this. I also pumped up the tires to spec, changed the oil using 10w30 petrol based oil and lubed the chain. When the weather clears up I hope soon to have some baseline mpg data to report. |
I just bought a 2009 dr 200, brand new from a showroom for 3000 bucks. 1.2 km on the clock, found this old thread while searching info on what exactly I bought
I measured the fuel economy for all of 2011. The cumulative average was 94.6 mpg, with a best of 97.8 on one tank. This is mostly urban riding with some riding up in the hills thrown in. The bike is completely stock, running synthetic oil. It is a great machine, which I use almost every day. I am really happy with it.
