Old 07-26-2008, 10:03 AM   #1 (permalink)
Wally's Aveo - '07 Ford Aveo
Question Ford Aveo computer change Rpm shift?
My 2001 Nissan Sentra got 32 mpg around town. It died.
My 2007 Aveo is getting 24-26.
I am sure it is the lousy high shifting. I would shift my Sentra @ 18-20K rpm. Every gear on this ford is high. The highest limit in my drive is 40 mph. This dang Thing shifts@ 33Rpm@ 45 mph.
The questions: can U take it somewhere and ask them to shift this thing lower?
It drives me crazy pul|ing out slow and this thing reving so high and there is nothing I can do. What should I do, go faster so it will just shift? Tapping the gas can help it shift, but I don't really understand how to do it accurately...
frustrated...
wally
Old 07-26-2008, 10:21 AM   #2 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 60.16 mpg (US)
Hi Wally -
Have you tried briefly lifting off the pedal to induce a shift? That works on some automatics that shift based on load/pressure.
Old 07-26-2008, 10:54 AM   #3 (permalink)
hmmmm...i dunno. I will see what I actually do.
There isn't a set way to shift it though is there?
I couldn't tic off a mark @ given mph OR rpm because depending what kind of incline or how much I am pushing on the accel will change everytime, yes?
Old 07-26-2008, 11:02 AM   #4 (permalink)
akcapeco's Avatar
V-strom 650 - '07 Suzuki DL-650 V-strom
90 day: 55.03 mpg (US)
07 Focus ZXW - '07 Ford Focus ZXW SE
90 day: 30.09 mpg (US)
It scares me to twice see references here to the Aveo as a Ford.
Old 07-26-2008, 11:09 AM   #5 (permalink)
looking for my epa, i was looking for the aveo....under Ford. of course I just didnt say that in the msg, i say it in the TITLE
None of our u.s. makers make enough of an impression for me to actually tell them apart anyway.
And thank you for everyone not reaming me on this.
Old 07-27-2008, 12:16 AM   #6 (permalink)
You could change out the valve body in the transmission. Lots of hot rodders do this, mostly to RAISE the shift point. But a couple kits made it basically a manual trans without the clutch. Shift as high or low as you want.
Don't if anything like that exist for Aveo though...
Laurence
aveo, shifting
Ford, making money? It must be a mistake... SVOboy General Efficiency Discussion 3 04-28-2008 09:28 PM
