EcoModder.com
-   General Efficiency Discussion (https://ecomodder.com/forum/general-efficiency-discussion.html)
-   -   syncro-mesh (how it works - youtube) (https://ecomodder.com/forum/showthread.php/syncro-mesh-how-works-youtube-28158.html)
arcosine 02-06-2014 01:28 PM
How a transmission works
http://www.youtube.com/watch?v=JOLtS4VUcvQ
mechman600 02-06-2014 02:14 PM
Maybe back in the 50s. Sliding gear transmissions have not been used since. In modern transmissions, the gears stay stationary and collars slide on the output shaft:
http://www.youtube.com/watch?v=IKywZ730JFs
arcosine 02-06-2014 07:35 PM
1936, I was looking for an example od a non-sycromesh transmission, like the reverse gear in your picture. Are then splines that the reverse gear slide on integral with the outout shaft?
Cobb 02-06-2014 07:39 PM
So much for an intelligent conversation about the lubricant thats safe for yellow metals. :eek:
user removed 02-06-2014 07:42 PM
That's a crash box (first post).
regards
Mech
arcosine 02-06-2014 07:48 PM
http://www.youtube.com/watch?v=IDiPWUy7BZ8
user removed 02-06-2014 07:49 PM
I prefer spinning hydraullic rams.
regards
Mech
redpoint5 02-06-2014 08:40 PM
Meshing all gears all of the time seems inefficient. Perhaps they aren't loaded so the friction is greatly reduced?
These videos remind me of how a differential works.
http://www.youtube.com/watch?v=yYAw79386WI
some_other_dave 02-06-2014 08:49 PM
That's correct--there isn't a whole lot of friction because the gears are all spinning on roller bearings. Some power is lost just keeping everything moving, of course, but it's not as much as you might think from seeing that everything is always meshed.
-soD
Cobb 02-06-2014 09:43 PM
Yeah, its easier to move spinning gears and to get them to mesh with others vs having them at a standing still. Thats assuming you are using gears in the first place. :eek:
