Old 03-19-2010, 08:25 PM   #1 (permalink)
Scangauge: Bad pump messed up gauges
At a recent fillup, the car needed 24% more fuel than expected by the Scangauge. This was odd, as it's generally within 5%. Now all my mileage readings are significantly lower.
So, how can I 'throw away' info from this tank?
Old 03-19-2010, 10:08 PM   #2 (permalink)
...beats walking...
...can you readjust the FILLUP value (up or down as necessary) until the "±%" number is *back* to what it was before? Of course, this assumes you wrote-down or recall what that number was before.
Old 03-19-2010, 10:18 PM   #3 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
Old Tele man -
I agree. I also think you can leave the SG unconnected for a while and it will reset to defaults.
CarloSW2
American Solar Energy Society
Old 03-20-2010, 10:03 AM   #4 (permalink)
ECO-Evolution
Lazarus's Avatar
Iron Horse (retired) - '97 Iron horse Intrepid
Ninja - '08 Kawasaki 250R
90 day: 76.23 mpg (US)
One thing you might want to check when this happens is if somehow the SG went back to the default values. I"ve had my SG I reset several times that gave me incorrect values.
If you driven it with wrong numbers I think all you can do is just reset it like you filled it up and just ride out the tank until it's time to fill up again. You probably need to confirm the setup values again.
"Judge a person by their questions rather than their answers."
What gauges do you use on your scangauge? regor EcoModding Central 15 03-22-2013 04:56 PM
Heat Pump Temp Lockout Settings to Gas Backup RH77 Saving@Home 3 03-11-2012 09:41 AM
What are your 4 favorite ScanGauge Gauges? armycopter Instrumentation 37 08-14-2010 12:57 AM
Hydraulic Hybrid Vs. Electric Hybrid jason.thompson EcoModding Central 20 09-15-2009 07:39 PM
ScanGauge is bad for MPGs Tango Charlie The Lounge 2 08-10-2008 12:29 PM
