Tach swap? G13 tach in G10 car?
My car is a 1993 1.0L Metro. I want a tach and would rather have the oem tach in the instrument cluster than an add-on tach. But the only car in the salvage with an oem tach is a G13 4-cylinder car. Can a 4-cylinder tach be adapted to a 3-cylinder car?
Pretty sure it's a wiring job.
For example, I have an Integra GSR cluster in my Honda Civic. Any pics? |
If you dig around on teamswift there is a post on there showing what resistors to swap out to get it working on a 3 cyl. It didn't look that hard to do really so it might be worth digging around over there and seeing what is involved in it.
The problem with using a 4 cylinder tach in a 3 cylinder is that the tach reads output from the ignitor and does math.. x/4 = RPM. Lets say x is 4000 on the 4 cylinder, your formula is
4000/4 = 1000 RPM (idle... ) Now, lets assume you put that cluster in your car, and don't change anything about it. 4000/4 = 1000RPM for a four cylinder, but for the 3 cylinder, the actual formula should be: 4000/3 = 1333.33 So basically, your engine is revving 1330 RPM when your tach is displaying 1000 RPM. The difference won't be linear either... it's a curve. 16000/4 = 4000, 16000/3 = 5333.33. Now, if you can change caps or resistors to make it do the math correctly, then you're set to go, but just using it without modification will definitely yield an incorrect reading. |
Taking it apart and printing out your own label might be an option too, no electronics but a bit of artwork to sort out.
http://opengauge.org/diympggauge/analog/pic5.JPG |
And the difference is linear. display=actual * 3/4 Apparently 3 cylinder oem tachs were rare, but not nonexistent. |
Just a quick addition the above post, the clear and black plastic have two long screws through them in the upper corners, but that's about it. Also, speedometer calibration is a big PITA.
