Old 09-09-2009, 04:06 PM   #1 (permalink)
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 18.97 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
torque converter lockup button theory
What if i installed a momentary lockup button and just held the button on accel. and then let the converter stay locked up on its own at cruizing speed? My book says the converter unlocks when no gas/decelerating so that explains why i can coast almost as well in gear as i can in Neut. I can actually feel it lock back up when i put my foot back on the gas.(feels like a little "tap"). please let me know if i have someting wrong but it seems to work in my head.....
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
Old 09-09-2009, 07:39 PM   #2 (permalink)
micondie's Avatar
moby van - '03 Dodge Caravan SE
90 day: 19.74 mpg (US)
The only potential problem I can see is your computer. You would have to have a double throw switch, wired so that your transmission would either be getting voltage from your computer or your other source with no voltage going to the computer. I don't know if this would damage the computer but it would probably set a code.
Old 09-10-2009, 12:50 AM   #3 (permalink)
wagonman76's Avatar
Red Car - '89 Chevrolet Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 Pontiac 6000 LE Wagon
90 day: 28.26 mpg (US)
Yes you would have to work around the computer. The 3800/4T60E compares RPM with road speed and is pretty sensitive to any discrepancies between the two. If the TCC even slips when it shouldn't, it throws a code and locks you out of TCC and OD till you shut it off and restart.
Winter daily driver, parked most days right now
Summer daily driver
Old 09-10-2009, 09:52 AM   #4 (permalink)
Team Pontiac
how can the comp. lock me out if i an using manual switches?
I found out the shift solenoid sequence for shifting:
GEAR SOL#1 SOL#2
1st on on
2nd off on
3rd off off
4th on off
And the PWM solenoid controls how hard/soft the engagement/release is so it makes my TCC wear faster!!!!
I am not going to ask if there is a way because i know there is. HOW do i disable the PWM solenoid or at least make it firmer?
I am planning on using a rotary switch for shifting and a button/switch combo for TCC. please help
1991 F-250:
Old 09-11-2009, 03:03 PM   #5 (permalink)
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
This is where I found the info for my shift project.
The Free Mod Series: Part VIII Electronic Transmission Controller - Toyota Forums :: Toyota Nation
The concepts are the same for most ECT's You might need to change the wiring of the switches if the shift pattern is different and the resistors based on the resistance of your solenoids under load. I imagine that its similar though.
Vortex generators are old tech. My new and improved vortex alternators are unstoppable.
"It’s easy to explain how rockets work but explaining the aerodynamics of a wing takes a rocket scientist.
Old 09-11-2009, 10:37 PM   #6 (permalink)
IsaacCarlson,
T/C lock up clutches are not designed to transmit the full torque of the engine which is why they only lock up at cruise.
A lock up clutch is around the edge of the T/C and is much smaller than a convention clutch in a manual (stick) shift gearbox.
Your lock up clutch may have a short life if you do as you are planning.
Pete.
Old 09-11-2009, 11:37 PM   #7 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Originally Posted by Peter7307 View Post
IsaacCarlson,
Pete.
How often have you heard of a hypermiler driving while using the full torque potential of the engine? I mean, seriously... besides that, I know several drag racers that use the TCC lock manually, and haven't smoked it yet. They're putting a lot more force against it than we are, so I think we're safe.
The Following User Says Thank You to Christ For This Useful Post:
IsaacCarlson (09-12-2009)
Freezing the Slushbox. Torque Converter on-demand lockup switch. orange4boy EcoModding Central 269 06-13-2015 09:51 PM
DIY: Push Button Start SVOboy DIY / How-to 20 07-10-2014 09:43 AM
Torque Converter Ferr3t EcoModding Central 32 02-02-2014 12:00 AM
