EcoModder.com
-   General Efficiency Discussion (https://ecomodder.com/forum/general-efficiency-discussion.html)
-   -   Tallest displacement*gearing vehicle? (https://ecomodder.com/forum/showthread.php/tallest-displacement-gearing-vehicle-38025.html)
Ecky 12-05-2019 01:21 PM
Today I was thinking about a fun, vaguely efficiency-oriented stat - displacement-gearing. To use my Insight as an example, the stock engine was a 1.0L with a 0.710 5th gear, 3.208 final drive and 0.57m (22.5in) diameter tires. We could use circumference too.
With the engine, smaller is better. With gears, smaller is better. With tires, larger is better. Liters and cm are arbitrary.
With these stats, the stock Insight was 1.0 x 0.71 x 3.208 / 0.57, giving a very arbitrary ~4.0 liter revolutions per meter (I think?).
With the 2.4L engine, I get 2.4 x 0.647 x 3.4 / 0.57, or 9.3 liter revolutions per meter.
I'm certain there are other factors we could add in, but what are some numbers for other vehicles? I'd like to see how various cars, trucks and especially motorcycles stack up.
Gasoline Fumes 12-05-2019 03:43 PM
Nut Wagon (CRX HF trans): 1.5 x 0.694 x 2.954 / 0.6 = 5.1
Metro (with tallest FD): 1.0 x 0.757 x 3.524 / 0.578 = 4.6
1980 Chevy K20: 5.7 x 1 x 3.73 / 0.806 = 26.4
mpg_numbers_guy 12-05-2019 05:27 PM
Aside from the Insight you already mentioned, my 4-speed auto Civic was 1.7 x 0.674 x 4.067 / 0.615m = 7.58.
