EcoModder.com
-   General Efficiency Discussion (https://ecomodder.com/forum/general-efficiency-discussion.html)
-   -   Tank's got a new nickname (https://ecomodder.com/forum/showthread.php/tanks-got-new-nickname-11659.html)
Domman56 01-02-2010 02:04 PM
My elco is still always gonna be tank to me because it Earned it's name
but my pop's called it somethin the other day i thought you all might appreciate and i'm chaniging this to the liscense plate next year
"ECOMINO":thumbup:
What do you guys think
Frank Lee 01-02-2010 04:33 PM
i don't get the efficiency part of it :confused:
Christ 01-02-2010 06:52 PM
I'm not sure you'd get a friendly response from anyone about that actually.
You might end up with some angrily placed smog-related stickers, though...
If you think it's a good idea, that's great... I don't think anyone else will agree, though.
Now, if you were able to sustain an average substantially higher than other drivers, or had done some real modding and made it obvious that you're at least making an attempt at it, or anything of the sort, it would probably be a different story... thankfully, you'll only have to deal with your intended PUN until next registration time, if you decide to go through with it.
Frankly (Frank Lee.. LOL) I think you should take it as a joke, what your G-pa most likely intended it to be, and leave it as that for now. It'll still be available next time around. :thumbup:
alohaspirit 01-02-2010 07:44 PM
Tanks better
maybe if it got super great mpg, ran on biodiesel or was all electric
only then would it be an Eco-mino
Domman56 01-02-2010 09:13 PM
Originally Posted by alohaspirit (Post 151539)
Tanks better
it's getiin a duramax and being converted to run on biodiesel in the next year or so forgot to explain that part
That's been my goal since i got it and I finally have the money to do it
Domman56 01-02-2010 09:14 PM
yeah i think i posted this tread in the wrong part, i wasn't sure where to post it
alohaspirit 01-02-2010 09:24 PM
Diesels dont have to be converted to run on biodiesel. They can do it at anytime. However long time usage will need the fuel lines to be upgraded to Viton to prevent the Bio from dissolving your fuel lines/seals.
With small modifications you can run VEGGIE OIL. :thumbup:
(the first diesel engine was made to run on peanut oil, then switched to petrol-diesel because it was easier/cheaper and more "commercial")
I think this would go in Off-Topic Tech since it deals with the name of a car
Domman56 01-02-2010 09:31 PM
Ah cool thanks man
RobertSmalls 01-02-2010 10:04 PM
The car is actually only 3200 lbs with a V8. Strip out the gas-guzzling bits, and there would be plenty of payload capacity left for lead-acid batteries. If you did an EV conversion, you'd have one of the quirkiest cars around. Electromino.
alohaspirit 01-02-2010 10:14 PM
Hmmm...
Electromino vs Veggie Oilmino
id pay to watch that
let the battle begin!
Frank Lee 01-02-2010 10:30 PM
put an mpguino in the meano, don't forget the beano if yer headed down to Reno but do leave out the vino or the cops will clean yer... o. :thumbup:
Christ 01-03-2010 12:03 AM
Oh no...
MC Frankly...
alohaspirit 01-03-2010 01:26 AM
ecomodder rap ft?
lolz
