Tapping into signal wires
What is the best (ie safest) way to tap into a signal wire? There are a few sensors that I'd like to monitor, the "signal" is usually just the voltage (eg 0V=open, 5V=closed, etc). Since taking the plug or socket apart is too hard (if at all possible), I have to somehow get into the wires. I can see three options:
If its temporary, I'd do #3. Put some electrical tape over it after you're done just to be safe.
I'm not sure if they are available in Poland, but here the auto parts stores carry splice taps.
they clamp on to the wire and provide a 3rd port for a new wire. when removed the insulation only has a small nick like your needle idea. example: BWD CT617A - Terminal | O'Reilly Auto Parts |
solder a lead to the pin, then stick it into the wire. Wipe a little silicone sealant over the hole(s) when you take the pin out if so inclined to restrict further oxidation.
If you can get at the ends of your wire harnesses (e.g. where they enter the ECU), you can get a narrow probe in there without piercing the insulation.
Apparently what you are seeking is a way to read the voltage of the wires by piercing but not cutting the insulation. It's called pick probing. You will need a few, very sharp dental instruments that can pierce through the insulation of the wire just enough to make contact with the wire. The handle end of the instrument will be attached by an alligator clip to the meter you are using. When you remove your pick, the pin prick in the insulation will be so slight as to need no remediation to the wire or its insulation
(I've only been using this technique for 40 years. If you find it useful a 'thank you' would be appreciated.) ;) |
you could get another connector, and solder pins on the end to fit into the original connector, splicing off a wire as in #1. then when you're done, just unplug your "piggyback" setup, and plug the original connector back in. sort of a man-in-the-middle type setup, and no worries about corrosion/broken wires with method #3. just a thought.
+1 for method #3, the 'pin-thru-insulation.'
...and a single wrapping of self-vulcanizing tape seals everthing up tight. |
T pins or AES Wave Pin Probes
http://farm3.static.flickr.com/2524/...f1cd0059_b.jpg
do not poke a hole in the insulation , you will allow the green fuzzies to start forming inside of the harness and the wire will dissolve from the inside out you will have a voltage drop that you will not know how to find AES WAVE sells probes , pin probes that will connect to leads for fluke and pico and other better quality test equipment . like this connection to the signal pin of a Geo Metro Map Sensor http://farm3.static.flickr.com/2468/...ed91151d_b.jpg |
BTW, I said "heftier" than a pin - but by that I mean stronger, not heavier or fatter. |
You can use RTV to seal up any holes made in the wiring insulation. That, or F-4 tape should suffice. If possible, though, heatshrink tubing is preferred over either of these solutions.
My personal preference is to strip off the insulation from the signal wire in question, solder the other wire to it, then seal up the stripped part. Usually, I can get the splice near a wiring connector, which means I can take the wire's pin out of the connector and use a section of heatshrink. |
I talked to an EE friend of mine about the taps. His opinion was that for something that is out of the weather in the interior of the car, a good-quality wire tap is a perfectly fine way of tapping into a signal wire.
I will admit that the thought of using them still doesn't make me very happy, though. -soD |
I don't like crimp connectors for use in wire joining either. Between possible loosening and potential for corrosion, I avoid using them. |
Copyright ©2000 - 2022, vBulletin Solutions Inc.
