EcoModder.com
-   Off-Topic Tech (https://ecomodder.com/forum/off-topic-tech.html)
-   -   TaxiBot for airliners (https://ecomodder.com/forum/showthread.php/taxibot-airliners-11076.html)
NeilBlanchard 11-20-2009 11:20 AM
Hello,
Here's a sensible device:
http://bioage.typepad.com/.a/6a00d83...7bb5970b-800wi
(click on image for link)
It moves the airliner while it is on the ground, which saves jet fuel.
Piwoslaw 11-20-2009 01:48 PM
Looks like the tractors that push a plane away from the gate. If they can be used for running up and down the taxiway to reduce fuel, then very good:)
There was once a thread at the HalfBakery about using linear motors to catapult planes on runways, aircraft carrier-style. The final concensus was that the beefed up landing gear needed for this would delete any fuel savings from assisted acceleration.
FastPlastic 11-20-2009 02:21 PM
I like the idea:thumbup:, but I have one thing to add. Unless the air conditioning truck is there the plane would still needs to run the engines for the AC.
wdb 11-20-2009 04:11 PM
There you go thinking about the welfare of the passengers again. That's so.... ...80's. Next thing you'll want is an airline passengers' bill of rights!
theycallmeebryan 11-20-2009 04:38 PM
Why not have chained tracks along each taxiway that the front landing gear latched on to? It could be electrically powered like a ski lift or the lift of a roller coaster, instead it will pull the plane along the taxiway. :thumbup:
Copyright ©2000 - 2022, vBulletin Solutions Inc.
