Old 06-17-2025, 02:04 PM   #111 (permalink)
90 day: 51.16 mpg (US)
The fallout from a gigawatt hour of lithium ion batteries sprinting towards net zero.
https://youtu.be/E68F503mM5o
LG just can't catch a break...
This makes one wish they could get a nuclear power plant in their back yard.
Have all the Gigawatt+ storage facilities had fire issues? Seems like whenever we hear about a new one that was built, we hear about a fire later.
Old 06-17-2025, 04:33 PM   #112 (permalink)
Afaik, the only reason they should get hot is rapid charge/discharge with inadequate cooling. Not in use Storage temps go a lot higher and lower. So birdnest or tumbleweed in the ridicously small radiator and they should go offline. That might start a cascade, but just speculation by myself. Always does start in weakest cell however because it's nearest the fire conditions.
Old 06-17-2025, 05:32 PM   #113 (permalink)
I don't know what LG is using for these batteries, but they had a manufacturing problem causing a bent anode and torn separator in their prismatic cells that lead to fires.
As I've been saying, a system that requires zero defects to prevent a cascading fire is not a well engineered one. Any individual cell failure, or battery bank, should not cause the entire system to burn to the ground.
Old 06-18-2025, 09:44 AM   #114 (permalink)
Agreed that a (battery [module]) failure shouldn't cause a fire, BUT, it has. Any where there is densely packed highly reactive components stuffed into a box.
Old 06-18-2025, 11:49 AM   #115 (permalink)
My point is the fire is the evidence of poor design. There should be enough separation, containment, or fire suppression of modules that runaway fire is extremely unlikely.
Ideally the system would be resilient against intentional damage, and especially unintentional failure.
Old 06-18-2025, 12:11 PM   #116 (permalink)
Do any batteries that do not contain Lithium present a fire hazard? Lead-acid? Nickel-iron? Zinc-carbon?
RustyLugNut (06-21-2025)
Old 06-18-2025, 12:57 PM   #117 (permalink)
Even LiFePO4 are much less fire prone. I understand at scale they're more affordable too, so why isn't that chemistry being used in stationary applications?
The answer is probably that LG has their prismatic lines already ramped up, so they make what they have manufacturing capacity to make.
The Following 2 Users Say Thank You to redpoint5 For This Useful Post:
freebeard (06-18-2025), RustyLugNut (06-21-2025)
Old 06-18-2025, 02:13 PM   #118 (permalink)
You trade power density for more thermal stability. Lifepo4 is 2/3 power dense FLA is 50%. If you're commuting on the 605, kinda a benefit
Never exploded a FLA, YET.
Old 06-19-2025, 09:28 AM   #119 (permalink)
The batteries used are 'Second Life':
ie:
Once the EV battery has reached less than 80% of its capacity the manufacturers are desperatly looking for an alternate use for them so that the whole recycling thing 'recedes in the rearview mirror' to the point where it's no longer their problem...
The LAST thing an EV maker wants now is the General Public becoming aware of/experiencing the HUGE, toxic recycling issue they are currently future-causing..!
When I looked; all these stationary batteries were in fact Second Life, mostly from EVs.
Hence the completely inappropriate chemistry AND the increased risk of faulty cells.
redpoint5 (06-19-2025)
Old 06-19-2025, 09:40 AM   #120 (permalink)
China has banned EV battery fires:
https://www.google.com/search?q=chin...t=gws-wiz-serp
These guys are renown for trying to save 0.000000000000000000000000000000000000000000000000 1 cents on everything!
But I think the prospect of "Life in a Chinese gulag' is very likely to deter this 'genetic defect', resulting in below spec batteries ending up being quietly dumped in the sea or something instead.
