Tesla Model 3 battery degradation tuning
Hi,
I wanted to share my experimental tuning of a 2019 Std Rng Plus Model 3 to compensate for battery degradation. Widely reported, the first year is ~5% followed by a 1% loss every year. My battery is about 3-4% (not an easy metric) so I wanted to start a tuning effort to compensate for the initial loss. My first effort is to replace the OEM rims and tires with lower weight rims and lower rolling drag tires. My particular car has a single, rear drive motor and ~50 kWh battery, 2/3ds the size of the other models. This means I can 'lighten up' on the tire loads because it is ~600 lbs (273 kg) lighter. Furthermore, I drive in "chill" mode, about 75% of the maximum, "standard" mode. Using Consumer Reports claims:
An on-going experiment, the front tires have a low wear rating and a recent screw event meant the local tire shop would not repair it. The "Stop and Go" kit using a mushroom shaped plug failed so I reverted to 'sticky string' which so far, is doing OK. I have three candidate, front tires and am leaning to lowest rolling resistance tire with modest wear rating. Since the front wheels are not powered, they should have an 'easy life'. We typically saw ~2x difference between the powered versus unpowered tires in our past Prius. Source: https://teslaownersonline.com/thread...-2#post-290660 Enjoy! Bob Wilson |
1320 kg=2900 pounds. 600 lbs=272 kg I know it's just a typo. JJ |
How evenly does the battery wear? (Are some modules worse or better than others?)
Bob Wilson |
Bob Wilson |
Here are the first results:
http://hiwaay.net/~bzwilson/TSLA/mph_miles_010.jpg
My first thought is rear wheel well pants. I can test it using heavy paper/cardboard and blue sticky tape. I'll only need to replicate the 63 mph benchmark. This approach doesn't add a rotating mass to the wheels. There are rear spoilers sold but at $700, they are pricy and I'm seeing credible data showing a significant drag reduction. But I can hack-test with heavy paper/cardboard and blue sticky tape. Bob Wilson |
Something I shared at Fred's TDI:
Just sharing some data points: $37,990 - current price for Standard Range Plus Model 3 which includes basic AutoPilot March 26, 2019 bought mine $41,000 with Autopilot and Blue paintLocal electricity $0.11/kWh $2.70/100 miles ($0.027/mile) from house powerSuperChargers ~120-180 miles apart along Interstates $3.50/100 miles using SuperCharger point-to-pointOther electricity Can use RV and recreational area, NEMA 14-30 and 14-50 chargingTypical cross country trips: 714 miles straight through to Detroit, ~14 hours, $25 charging~90-95% of driving is using AutoPilot anywhere Handles lane changes with 360 degree camerasFull Self Driving (FSD), $6,000 last October Stop sign, stop light, yield sign logic works with "green light" PINGSelf-repairs Banged into curb on passenger side, stripped part of rims yet tires held airBattery degradation Measured 3-4% in first year, miles: (240 - 234) / 240 and (240 -232) / 240Maintenance Window washing fluidDriving "Chill" mode so it won't 'speed frantic' in trafficCross country 1st leg with 100%, overnight charge to go as far as practical, ~210 mi, ~3 hoursSUMMARY Half the cost per mile of our former Prius Prime and fun to drive. The driver assistance of AutoPilot and FSD, makes long distance and even city driving safer, easier and relaxing. Bob Wilson |
Not to be picky but your Prius Prime would have made a 714 mile trip in 11 hours and cost the same $25 in "charging". Not sure how you get 1/2 the cost per mile. How long did those Model 3 tires last and how much were they to replace? That alone would buy years worth of Prius Prime gas, and a Prius is super easy on tires.
In Huntsville, the Prime became a ‘3 stop’ EV car while our BMW i3-REx was a ‘10 stop’ car. The BMW was used and the Prius Prime became driveway art. The majority of our miles are urban and that is where the Prime failed. I was looking at a significant capital expense, $29,400, that was not returning value. So I traded it in, $18,300, for a Std Rng Plus a Model 3 that is cheaper both City and Highway. My capital expense must carry its weight. Bob Wilson |
So you are counting the maximum possible depreciation cost by trading in after one year as a cost against the Prius? Are you only allowing the Prius to be used in EV mode? That seems like an unfair use, the whole purpose is to use that 40 mile range 80% or the time but then let the gas kick in when you need longer trips. Otherwise you are hauling around that big engine for no reason.
I just think in a fair comparison, normal usage, taking in all factors, no way the cost per mile on a model 3 is 1/2 a Prius Prime. Maybe pick something less efficient or more expensive car and you would get there, but a Prius Prime is not a high cost per mile car. Your Tesla is a $47,000 car, you don't get to reduce it's cost by counting the Prius trade value as some kind of offset. If the Prius was a mistake for you, if anything that cost goes onto the Tesla's cost, not reducing the Tesla cost. If you look at your overall cost per mile over the last 3 years you are basically doing terrible. My $3500 3/4 ton Suburban does better getting 12 mpg. |
Capital has a cost that trading in the Prime salvage value, $18,300 significantly reduced the capital cost of our 2019 Std Rng Plus Model 3, $18.3 / $41 ~= 44.6% down to $41,000 - $18,300 ~= $22,700 for a new Model 3. The Prime cost ~$29,000 in Rhode Island. We've run the experiment and the Model 3 returns the greatest value. The BMW i3-REx, next, our backup. The Prius Prime least so we traded it in for the Model 3. Bob Wilson |
