Test: F-150 pickup "cap on" vs. "cap off" @ 60 mph
Found an interesting efficiency test done by an owner of a 1994 Ford F-150 pickup.
His goal: "to finally (we hope) determine the best configuration for fuel mileage" between...
http://ecomodder.com/imgs/ford-f150-cap-on.jpg http://ecomodder.com/imgs/ford-f150-cap-off.jpg 1994 Ford F-150 XLT with an 8 foot bed, 5.8L V8, automatic Note the vehicle year: 1994 - so, no ScanGauge. That created challenges for collecting data. Fortunately, we have a creative problem solver. What he did instead was to install a $5 used GM Manifold Air Pressure Sensor into a manifold vacuum line, the voltage of which he could monitor while driving. (I can hear Coyote X now... "COAST DOWN TEST! COAST DOWN TEST!") Over the same 9 mile stretch of Interstate, on the same day, using cruise control, he & his son ran the truck in the 3 configurations, taking readings from the pressure sensor every 15 seconds to chart engine load. The results were charted and the values averaged: http://ecomodder.com/imgs/ford-f150-...tRunsChart.gif (Click through to the owner's site to see the full size version of this chart.) Not surprisingly, the camper shell run had the highest average load. However the owner was surprised to learn that the lowest load was with the tailgate up. His site has more information about the day's events, his MAP sensor circuit diagram, and another chart of the MAP averages. Check it out: Test to Determine the Relative Engine Load - With or Without a Camper Shell (and with the tailgate up or down) |
Just an observation about this little experiment:
The canopy on that truck is very boxy, which obviously will increase its drag. Most of the canopies on trucks (atleast, most of the ones I see) are rounded off, and have a cleaner profile than this one. Also, look at that space between the cab and the canopy... That's a pretty large space, especially towards the top. It's known that the size of the space between the bed and the cab affects the aerodynamics of the truck, and I'm sure the canopy is no exception. Don't take my comments in a bad way, it's a good experiment! It's especially good for the owner of the truck, and people with the same or similar truck and canopy. I just wanted to point out a couple of things that could change the results that, I'd say, the majority of other people would get if they did this. I plan to do a similar experiment this summer, except I plan to do it with a week, or a month, for each different setting. |
None of the regulars here are suprised, are they?
5 Attachment(s)
I was sure that my cap is better than the bare truck. But now i have to check it.
yes, you ideally want a "clean break" at the rear, but the front edges should (again ideally) be rounded.
In this test I don't really think that having the leading edge being "boxier" would effect the outcome very much. Seems to me that the results are pretty clearly showing the effect of trailing wake. With the shell on, the trailing wake is as big as it's ever gonna get, therefore the mileage suffers. With the shell off and tailgate up, the trailing wake is smaller, and (I think) the air can best approximate the "ideal" flow, coming down from the cab at approximately 13 degrees, just clearing the top of the tailgate. Clearly it's better to not have the air "approximate" it's ideal line, but to give it an actual form (aero cap) to flow over. With the tailgate down I would think that the air is no longer being "fooled" into following the 13 degree angle, so it's just separating off the back of the cab much like it would separate off the back of the camper-shell. |
I believe mythbusters busted the tailgate up down scenario..
however, my other truck did so much better with the tailgate down, I could actually get it upto 90 much faster (3 second difference) with it down vs up.. but it wasn't a traditional cab on frame with bed setup. http://i4.photobucket.com/albums/y10...T/MVC-274S.jpg when I took it to the drag strip to dick around with it there, I deleted the tonneau, tailgate, bumper, inner bed panels, spare tire and spare holder.. shedded quite a bit of weight.. with a whopping 60whp I did good at the track doing bracket. F bomb warning.. in the in car video, we were all making fun of the fast n the furious.. ;) Looks like that MF stayed up.. the camera was wedged in the pass seat headrest. http://www.youtube.com/watch?v=ziNx0x_YXVw |
Hi Barwelle - welcome to the site....
But probably not dramatically worse. The problem, as andrewj pointed out is the size of the trailing wake - that's where most of the drag is. With a cap - rounded corners or not - it's going to be big, nearly 100% of the size of the projected frontal area. Quote:
Note that testing by the month or tank will produce much less accurate data than these guys got, because you can't control for weather, temperature, different trip profiles (speed, traffic) etc. |
A more scientific analysis suggested that, on average for a range of trucks tested, tailgate up is best. But in reality it depends on the vehicle: SAE report: Pickup Truck tailgate aerodynamics... better up, down, or off? |
I wonder if a "camper shell on, tailgate and camper shell door open" would have done better?
Plus the camper shell adds wieght. Bad aero+added wieght=:rolleyes:
I doubt the open tailgate would have any effect with the cap on - it would be fully involved in low pressure turbulence. |
My Isusu PU is one of those that has a drag with the tail gate up. I push through a big drag area going from 45 to 50. When I have the bed filled it just flies through that speed. With the tail gate down I don't get that drag spot but it doesn't feel as zoomy as when it's filled. Some day soon I plan doing coast down tests to get some numbers to see just how much differents there is, I'm also planning to make a aero back to test too.
oh also I've not felt this drag driving full size PU's and have not driven other small ones to campare too either. So I can't speak for any thing other that this one, but no hard data to show for now. |
Sorry for bump this old thread I am curious how to make GM Manifold Air Pressure Sensor work in 95 Ford F250?
How they get voltage info? Would it able work permanent ? I am curious how drag on Flatbed and brake before I fix or change them so I want know what mpg or voltage was that after I change.. |
This cap has big flat surfaces exposed to airflow, because it's bigger than the cab, unlike most modern ones.
the GM MAP sensor is just a sensor, you TEE it into an existing vacuum line on the engine It uses a 5V source, Ground and give an output the varies with the amount of vacuum the engine has. I have a Suzuki GSX-R 750 MAP sensor on my '91 Nissan 240SX for testing purposed for a project engine I'm building... |
the saturns have one bolted on top of the manifold.super easy to get to. is there a gauge you can hook up to, for readings?
