Test Thread
Test Thread
Results?
Wrong sub-forum?
Admin asked me to post a test thread because I’ve tried posting 2 other threads that just disappear.
The situation I'm having is a post that goes to a new page and then when I click next it loads the same page. :confused: Check to see if there is a subsequent page that doesn't load.
The fix that was suggested is to change the number of posts per page. HTH |
RLochard -
Try posting your build thread again. I can't explain why the thread title remained in the subforum index, but the thread itself was missing. To simplify, I'd omit adding tags in the first post. |
Oh noooo. It did it again! It posted it but there’s nothing there. I may have broken the forum :..(
It's not you, it's me...no, wait...it's you. It's all you. ;) Go start your thread again, don't put much of any content in it, see if it works...if it does, go back and edit your post to put in the content. If it doesn't, you've not wasted much effort. |
^ Agreed. Try again. This time, use a different thread title than you've been trying.
Something in it or the post disagrees with the forum software/database. |
Test Thread
Okay so this is the Fourth time I’m trying to post this. Hopefully it works!
I posted some of this in my introductory thread but I wanted to make a thread I can add to as time goes on and I continue my Ecomodding Adventure! |
